That said, I still have tubeless tires on my road bike. I’ve had very few flats since I made the switch, but before I did, they were not uncommon. I also like the lower pressures that tubeless allows me to run.
My understanding from the reading I’ve done, is that the rolling resistance penalty of a latex tube vs. tubeless in the same tire is effectively zero (BRR test results are within the margin of error). The weight penalty is a wash when you’re running enough sealant to fix a flat. Usually the main difference between ‘pure clinchers’ and tubeless tires is usually the pure clincher has a bit more center strip material as a hedge against flats, which is why tubeless tires usually test faster.
FWIW I run latex tubes in my road tubeless tires most of the time. I’d consider setting up tubeless for a super important event for the flat protection but otherwise road tubeless is more fuss than it’s worth.
Whatever those feel about operating tubeless, it is clearly a very subjective opinion.
My thought is it might depend on your experience, mechanical comfort and/or skillset.
For the most part, I find tubeless very much worth the minimal effort I find it to be.
With 25+ years of cycling & mechanical experience, I think the tubeless effort is not as difficult or a hassle as many feel.
As anything that one has performed multiple times, it usually becomes more natural and easier as the application is repeated. YMMV
I think the hassle is definitely overstated, I mostly stopped doing road tubeless because keeping a stable full of bikes topped up on sealant was annoying and switching the slick tires back to tubes is an easy move and a non-starter for the knobbies.
A rational thinking person should be able to freely determine if tubeless is for them or not.
No judgement, no prerequisites, just what you’re comfortable with.
This thread caught my eye because I just went through a sizing exercise with Vittoria N.EXT clinchers on my rim brake bike. I agree with a lot of what has been said.
- I want tubes because my rim wheels work fine with tubes and tubeless road at 70psi seems potentially sketchy.
- I was on GP5000 700x28 Tubeless tires, with a latex tube
- The 700x34 N.EXT on a Pacenti 19mm rim measures out to 32mm and just fits my bike. A 700x32 measures out to 30mm wide and fits my fork.
- Tubes are less messy to change, and are pretty fast for me. I almost never need tire irons.
- I talc the tire and tube a lot to keep sticking down.
- In my first 3 weeks on the N.EXT, I got 3 flats. A snake bite (low pressure, pot hole, butyl tube), a valve bond weak spot failed (old latex tube), and an unknown cause - perhaps it was the old butyl 18-23mm tube in a 34 tire…
- I replaced the rim strip and installed a TPU tube. At 64 psi, the ride feels harsher than the GP5000. Until I get more time playing with pressure, I can’t be sure if its really the tire though. But the tire has a lot less rubber, and TPU seems much less elastic.
I remain curious how I will feel about TPU tubes - they definitely feel easier to use and install than latex tubes - they hold shape immediately at the target size
I will probably try to get a higher quality clincher next time. TPU is so light, I’ll use a tubeless tire with TPU tube if the clincher market gets awful. TPU is 30 gms. 1 oz of fluid weighs 28 grams. 2 oz of fluid is 56 grams. I don’t really care about the weight, but want to point out that TPU is probably even with sealant from a weigh perspective
Whatever works for you is the prescription.
The GP 4000 SII is an old tire design
, built for rim widths typical of that era. Meaning, 13C and 15C rims. They do run true to size on those rims.
Please don’t get me wrong, I use that tire for my rear wheel and like it a lot. On my 19C rims, the GP 4000 SII 700x23mm measures 26mm (using a caliper).
Back to your original question: the tubeless tire itself will run at least 40gr heavier than the equivalent (tubed) clincher. If you care about weight, don’t choose the tubeless version.
However…when tubeless came in vogue, all the tire research went into the tubeless tires, leaving clincher product development outdated. It is hard to find a recently-designed tubed tire, though this is finally changing. Thus, your compromise is a heavier tire with potentially better rubber compound and typically better design or a significantly lighter clincher (i..e. GP 5000)
One more thing: latex inner tubes seem so finicky. TPU all the way if you use inner tubes.
- Far lighter than latex,
- They hold air infinitely longer (latex are notorious about their air retention) and
- So much easier to install than latex.
- Bonus: when you puncture a TPU, it will likely get you home, or at least another 10km down the road. Butyl and latex let go of their air on the spot, potentially causing you to lose control if you puncture the front tire on a descent.
- Clarification: I use the 40gr TPUs. The 26gr ones do seem far more fragile and also are typically not rated for rim brake wheels.
I have personally tested what I wrote about. As a physicist, I am all about experimenting.
I hope this helps.
The original GP 5000 TL was a right pain in the rear to dismount and remount after installing an inner tube on the side of the road. Broke quite a few tires levers trying to do this. Thankfully, the GP 5000S TR is so much user friendly.
The tubeless tires don’t seem to play well with older rims that lack that recessed center channel on the rim bed. IIRC, the tubeless beads are stiffer as they have to retain shape without the inner tube, hence the challenge.
When used with a modern rim that features the recessed center channel, frankly I don’t have to use a tire lever to mount the tire with a tube in it. I am not …superman
, I simply use that center channel to effectively reduce wheel diameter. Also, I find it is key to mount the tire area by the valve stem last (as it keeps the inner tube from popping out of the rim).
YMMV, simply relating my experiences and wishing to be helpful.
I had the same issue recently. I bought an older set of Wheelworks Maker wheels that are about 20mm internally. My old 25s measured almost 28mm in them with room to spare. So, I bought 28mm GP5000s, and they only measured 27! I ended up with the 30s measuring about 29. ![]()
As far as I can tell, Conti increased the widths of their reference rims and recalibrated their listed widths to account for rims getting wider, but they only published two of the reference rim sizes as examples in general articles about their tyres on their website. At least some companies, like Pirelli, write the reference rim size the tyre is measured on the box so you have some idea of what you’re going to get.
Not all butyl tubes are created equal either. I prefer to use butyl because it’s the least hassle, but I use Pirelli RoadTUBEs which are lighter, softer, more compact, and faster. But clearly speed and weight are not my greatest concerns. I still enjoy riding my bike, and it’s fast and comfy enough. I enjoy it more too because I don’t have to deal with the tubeless maintenance.
compared to standard butyl tubes.
Here’s an AI summary from BRR and a few other sources comparing the GP5000 and the GP5000S TR:
Key Takeaways & Trade-Offs
• The Rolling Resistance Paradox: Counterintuitively, the tubeless-ready GP5000 S TR rolls faster than the standard GP5000 even when a tube is placed inside both. Continental achieved this by dropping a casing layer in the S TR (moving from a 3-ply to a 2-ply setup under the tread), making the overall tyre structure significantly more supple. This structural flexibility easily overcomes the friction of an inner tube.
• The Weight Penalty: The standard GP5000 wins on the scale. Because the tubeless-ready version requires a much heavier, thicker bead to lock safely into tubeless rims (and hookless rims), the bare tyre is roughly 34–35 grams heavier out of the box. When you add the weight of a standard butyl or lightweight TPU tube to both, the standard clincher setup will always be lighter at the outer rotating edge of your wheel.
• Puncture Risks (The Danger Zone): This is the biggest caveat to putting a tube in the S TR. The standard GP5000 clincher has a much higher tread puncture score (49 vs 36) because its 3-ply casing naturally resists sharp objects better. The GP5000 S TR relies heavily on liquid tubeless sealant to patch holes dynamically. If you run the S TR dry with an inner tube, you inherit a thinner, more puncture-prone tread without the self-healing benefit of sealant.
The Recommendation
If your intention is to strictly use inner tubes full-time, buy the standard tube-type Grand Prix 5000. It is cheaper, lighter, much more protective against standard punctures, and fits more easily onto traditional hooked rims.
Only use tubes in the GP5000 S TR as a temporary, emergency roadside fix to get home after a major tubeless puncture that sealant failed to close.
It really comes down to what you value most (performance, low maintenance/hassle, cost, availability, etc.).
Re changed reference rim sizes: The culprit here is ETRTO, not Conti. I’ve no idea what the design rim widths were in the rim brake days, or indeed if there were any, but now they’re wider. From an EC article it’s apparently as follows:
Tyre width - Design rim width
18-21 - 15
22-24 - 17
25-28 - 19
29-34 - 21
35-46 - 23
47-57 - 25
Normal racing practice these days seems to be to run the widest rim that might work, or else that is allowed by ETRTO/ISO in top level events where the UCI has banned non-compliant combos. It’s pretty much the Wild West out there with tyre and rim width matching, especially for gravel. Some things that used to be standard practice BITD are now officially frowned on. ![]()
Thanks. That’s useful. I did have a look for that a while back, but I couldn’t find it. My issue is not that they changed the widths but that they don’t publish what they are. It would be very simple to write it on the box on on their site the way Pirelli does.
