What kind of difference does is make to use tires that are purely clinchers, i.e. have to use tubes, vs. tubeless tires when one is going to use tubes anyway?
I have no interest in tubeless, but it seems the new higher performance tires are coming out only in tubeless versions. The GP5000 seems the best best, but it runs a little narrow from what I need, the “32mm” wide version measures only 30mm. I was thinking the Vittoria N.ext, which comes in a 34mm, though probably isn’t quite the quality level of the GP5000.
Or do I just go with tubeless tires with tubes installed, and maybe the Vittoria Corsa Pro Control in 700x34?
I think with butyl tubes, there’s quite a big difference no matter what tires you get. So if you want to do it at the very least go for TPU or latex tubes otherwise you might as well get the slower tires.
There was a bit of chat around a similar question in the discord. BRR results show GP5000 clincher with the top TPU tube is marginally faster than the tubeless version (in 25mm, which is the only size which BRR have comparable results for). Should be a bit lighter too.
Downsides are occasionally needing to deal with punctures, running a high enough pressure to avoid pinch flats, and ongoing question marks about reliability of TPU tubes if that is the route you go down. Latex tubes are more reliable, but reliably lose air over time. Butyl is reliable and pretty good at retaining air, but slower and heavier.
In terms of other performance options, Pirelli do the P-Zero Race and P-Zero Race RS in a clincher version. Although only up to 30mm (nominal) width.
I looked into Pirelli P-Zero Race RS clinchers but yeah, the biggest they make is 30mm, same with the Vittoria Corsa Pro clinchers… but these two are marginally slower than the GP5000 and wear out faster anyway, plus GP5000 are soooo common that they can usually be found for much less money.
If you’re going to use tubes, I personally think it’s better to use clinchers meant to be used with tubes rather than tubeless ready tires. If you compare the same tire in its clincher vs tubeless versions but both with tubes, the clincher setup will be lighter, have slightly lower rolling resistance as they are usually thinner and more supple and more practically, clinchers are usually quite easier to put on and off most rims (usually without even needing tire levers) and they are cheaper to buy.
A tubeless tire with a tube’s only advantage IMO is that it could potentially be marginally more puncture resistant since the casing is a tad thicker, not the casing per se but the construction usually have an additionnal layer for air retention… but if you puncture a lot, they wont make a big difference unless you run them tubeless.
I’m on team tubes as well for road bikes, I puncture about once a year so fixing one flat per year takes a lot less time and is so much less trouble than dealing with tubeless tight beads and topping off sealant… plus I never would want to ride low enough pressure that pinch flats are an issue, so tubeless has pretty much no advantages to me, but plenty of disadvantages. Off-road is another story.
I run 700x32 GP5000 clinchers with Pirelli SmarTube RS TPU tubes (the RS version is one of the fastest rolling TPU tube, on par with latex but lighter and with better air retention). I don’t know on what rims you end up with them measuring only 30mm but on mine that are 24mm wide internally, they inflate to over 33mm wide. I’m very happy with the speed/grip/weight/comfort/durability/lack-of-faff of this setup.
Exactly my position on a Cervelo Soloist with Reserve TA 64/57 wheels and go TPU tubes with Vittorria Corsa pr clinchers and after the Roman Opus have got some Pirelli P=zero Race RS clinchers to try .. both in nominal 30 mm width inflated to 68 psi (I am 70 kg)
The rims are older Rolf Tandem, 19mm internal, so that would explain some of the narrower measurement. I guess they may stretch some over time as well. The GP4000II tires that are being replaced are labeled 700x28, but measure 32mm on these rims. I do wish manufacturers could at least be consistent among different model tires.
That makes sense. GP4000 were notoriously big for their marked sizes, I’m not sure how they came up with the sizing back then to come up with tires so much bigger than claimed but Continental changed the way they size their tires when they introduced the GP5000. They since aim to have the marked size be closer to real width when mounted on modern rims, I think their sizing is based on 21mm rims which were the norm at the time… and they’re not that far off.
But as you know, narrower rims will give slightly narrower tires, wider rims wider tires, but the shape of the rim’s hooks can also change the shape and width of a tire, so in most tire companies’ defense, it’s hard to give a precise measure with so much variations coming from so many different rims.
I’m road tubeless w/ sealant and have been flat free for slightly over two years.
Where does the pinch flat issue and low pressure have a spot here on a road tire?
On average I get about one flat every year or so; dealing with sealant and super tight fitting tyres isn’t worth it. Latex tubes are also not worth it IME, needing inflation at least daily, in the middle of audax rides, and sometimes bulging or splitting.
WRT Contis, IIRC the S TR has fewer layers in the middle of the tyre than the clincher, so is more likely to puncture. I agree that it’d be useful if wider road tyres existed in non-tubeless form.
reading the answers here and seeing how many people still do tubes i keep on wondering why all these tire reviews and comparisons concentrate on tubeless. IMO there is not really any substantial advantage in tubeless for road. and there are still some good tube-only tire options (from schwalbe, conti, michelin, vittoria, panaracer) out there which are clearly lighter and hassle-free and most probably no rolling resistance or comfort penalties with modern tpu tubes. so why not get these properly reviewed and compared to the tubeless counterparts?? yes, this one goes out to the EC review department…
i would argue that most of us are not pros here so why not get some down-to-earth and not pro-circus options reviewed?
Perhaps I’m missing something — and if I am, my apologies — but isn’t this dictated to a pretty great extent by your rims? As in — most (or at least very many) newer tubeless rims are hookless, which means you must run tubeless tires on them, even if you run them with tubes, because of the bead interface.
FWIW, I will never try to convince anyone to switch to road tubeless — people should run what makes them happy — but I went tubeless on the road about six years and tens of thousands of road miles ago, and you could not pay me to go back to tubes!
My issue with tubeless is primarily the maintenance. I have more bikes that I would care to admit, spread out over 4 different locations on 2 different continents. If I could install a tubeless tire and that was it, then I might switch, but there is no way that I am going to keep fresh sealant in all of the bikes that I ride. I just want to be able to show up at my in laws, twice a year , for example, get on a bike, and ride.
I also generically, rarely get flats, so see very little advantage in a system that primarily offers a way to avoid a “problem” that I do not seem to have.
I have no hookless rims, so that doesn’t dictate the tires that I am going to use.
Honestly, the real problem with tubeless on bikes that aren’t ridden often is keeping non-hardened sealant in the tires. On my main bike, I’ve been using tubules for six years, and I rarely need to stop for punctures. and 90% of the time if the sealant won’t seal, a plug will fix it a few minutes.
But on my other bikes, that I only ride occasionally, I have switched back to tubes. The hardened sealant boogers are a pain, because you need to remove the tire and strip the dry sealant out, then start over.
For me the other big advantage to tubeless is being able to run the tires at much lower pressure. A lot of the roads where I live are pretty bad chip seal, and the bike just rolls a lot easier on rough pavement with lower tire pressure. And a free bonus, it’s so much more comfortable.
I’ve switched back to tubes on my road bikes for the same reasons. I was spending more time maintaining the tubeless systems than actually riding those bikes.
I’m happy enough with TPU tubes in the tubeless tyres I was previously running tubeless; the weight and RR increases are seemingly negligible. But when I do need to buy new tyres it would be nice to have some more tested options than just the gp5k and Pirelli’s.
BRRs puncture, traction and RR numbers make me question whether clinchers are always best when using tubes.
I think the sentiment is changing. Hookless seems to slowly going away (in favor for at least mini-hooks, not to loose face too much and keep part of production simplicity). And tpu tubes are getting more and more media attention, it seems.
Besides all the rolling resistance and puncture protections considerations mentioned in earlier posts one factor decided for me to only use clincher with tubes, not tubeless tires with tubes; ease of remounting a tire. In general in my experience (YMMW) it’s harder to mount tubeless tyres than clincher tyres (based on GP5000 and Pirelli P-zero race) which is 1) a giant pain in the ass and 2) increases the risk if pinching the tube when remounting the tubeless tire with a tube inside.
Again in my experience, i haven’t had much luck with tubeless setups on road. Maybe its because road requires somewhat higher pressures, but even with tubeless fluid that works perfectly well on gravel and mtb, it never seemed to seal up properly on road when i had a flat. In that situation, in winter, trying to violently remount a tubeless tire with a tube inside it while your fingers are freezing is just the ultimate exercise in frustration
Oh I haven’t answered the original post’s question in my first answer. here we go:
I would go with tube-type tires in a setup with tubes because:
tires are way lighter, even with a tpu tube the system is way lighter than tubeless
easier to mount
cheaper
zero maintanance
Vittoria Next and Rubino tube-type are available up to 34mm, super supple riding with tpu
Schwalbe One, One Plus and Pro One all up to 32mm
Panaracer Agilest Duro 30mm
GOODYEAR EAGLE F1 RS up to 34mm and Eagle up to 32mm
Pirelli several in the P ZERO range up to 30mm
Michelin Power Cup Competition Line unfortunatelly only 28mm
