True Clinchers vs. Tubeless tires with tubes?
Whether or not there is any advantage to tubeless road is dependent on what advantages a person sees and what he or she prefers. It’s also hard to say how many people still do tubes. Last I checked, there hasn’t been any data released on that. If you go by what comments are made internet comment sections, it’s more likely that people who don’t like tubeless will comment than people who do like tubeless. A number of studies have supported this phenomena where happy happy with product comment less than people unhappy with a product. You can’t really tell who using a tubeless setup vs a setup with inner tubes if you pass them on a ride. And how are we defining hassle-free? I’m not sure there’s a universal spec for what qualifies as hassle-free.
well, no one I personally know who rides road-bikes, and there are some, rides tubeless. not statistically relevant, but still.
Of course, an online forum is rarely a way for objective truths. so what I am writing is my opinion, which might be relevant for some readers who can agree what they see as an advantage.
And it would be really interesting how many people in this forum ride tubes and how many ride tubeless. From my very limited experience not alway what is given as state-of-the-art or claimed or or forced on us by the industry is the way people do or prefer things…
and: where do you see “hassle-free” in my answer? I have written “easier to mount” (which they are as the tires are softer and more flexible due to less material) and “zero mainatnance” (no milk stuff refill etc) which for me does not add up to hassle free
I’ve found tubeless a doddle to deal with. Mounting the tubeless tires (30mm GP5000 S TRd on rims with 25.4mm front/25mm rear internal width) was not difficult. They seated easily wth just a regular floor pump. I set a notification on my computer to remind me every 3 months to top off sealant. That’s a straight forward process, with no mess. I haven’t had any flats, but I have seen two or three little punctures that were sealed without me knowing. There was no sealant (Orange Seal, the regular flavor) all over the bike or anywhere on the bike.
Hassles? For a hassle was defined by a two week period, when I lived in Tucson, during which I had 10 flats. Three flats were on tubs, the other 7 were on clinchers. Goatheads are evil.
Are my tires and sealant heavy? I don’t really consider it. Bicycle wheels typically have very low moments of inertia, so I’m not gonna worry in the slightest about a 50-100g (plus or minus a few) increase in mass. The wheels with tires still feel fast. Road feel? I’m chuffed with the road feel of these very heavy, super thick, and uber stiff tire carcasses.
Want to experience what a real crap ride is? 19mm clinchers, butyl tubes, on 13mm internal width rims, and then take in some chip & seal roads.
I love my tubeless setup, and I’m not going back to tubes. Ride what makes you happy.
Easier to mount is based on your experience. For me, checking on sealant every three months is not a hassle.
FWIW, no one forced anything on me or my bike at all. The same was true of my previous bike, a Look 595 that I rode for 15 years. I chose to go tubeless in part because of the roads around me and also because of the lower pressures I can ride. That last part is important because the bike does gravel too. My Look 595 for the last 5 years of its life had 28mm GP5000s with latex tubes. There was no noticeable change in ride feel or comfort in going from those clinchers to my current setup.
As others have said, the ease of mounting regular tube type tyres would point me in that direction. I might be unlucky but i run tubeless on both my road bikes and they are a pain to dismount. Not something i’d want to do in the middle of nowhere, to change a tube. Even unseating from the rim edge requires effort (i use the vittoria air liner tool at home).
Simon
From Enve’s website:
MISCONCEPTION #2 – YOU CANNOT USE AN INNER TUBE ON A TUBELESS WHEEL OR WITH A TUBELESS TIRE
FALSE! An inner tube can always be used in a tubeless wheel or with a tubeless tire.
While you will sacrifice rolling efficiency and flat-resistance, tubes are compatible with tubeless tires and rims, but should be used as a backup in case of a rare but unfortunate tubeless flat tire. Should you experience a flat while running a tubeless setup, you can finish your ride and get you home by simply removing the tubeless valve stem and installing an inner tube, just as you would on a non-tubeless setup.
As said by others above, tubeless tyres are thicker as they act as a tyre and tube in one. Running a tube in a tubeless tyre will be slower and harsher.
Also isn’t it funny how every tubes/tubeless question just end us with people saying how one or the other works for them (with their unique road surface, climate, maintenance regime, etc) and never answers the question. No matter the website, always the same ha.
Someone suggested above that a large proportion of new road wheels are hookless, but I don’t think this is correct - unless you’re only looking at Zipp, Enve et al. The vast majority of non-Western branded wheels use either hooks, or sometimes “mini hooks” however one defines the latter, and even Enve are starting to use some sort of hooks again IIRC.
There are plenty of influential people who are opposed to hookless road wheels (for instance Josh Poertner), and I would never touch them. For very wide tyres run at much lower pressures hookless (and tubeless) make much more sense than they do for tyres around 30mm.
So, to get very specific, since there apparently are not any larger volume true clinchers out there that I missed:
If you had a choice between, say, the Vittoria Corsa Pro (or Pro Control) tubeless, vs. the Vittoria N.EXT clincher to run with tubes, which do you choose? The Corsa Pro is nominally a “better” tire, but do the downsides of tubeless with a tube outweigh the benefits of the better quality tire?
And, I guess, how far down the tire quality ladder do you go before you reach the tipping point? Corsa Pro vs. Rubino?
Yes, slightly so. I have latex tubes on my road bike running Conti GP5000s, and grav bike with Schwalbe G-One R. The grav tires do have very little pressure loss compared to the Conti GP5000s. That the PSI is lower to start with on the gravel tires may play a role.
This is true. But if you’re planning to use tubes then you really don’t want tubeless compatible tires - they’re much harder to get on and off. And then that means you can’t have hookless rims. So you need to be careful what you buy.
And I am still not clear whether you can use non-tubeless compatible tires on a wheel with “mini hooks”? Is the answer that it depends?
I found Corsa Control (non-tubeless) a bit more compliant than Corsa N.EXT. But they are heavier and more expensive. And they only ran up to 30 or 32mm, so now I’m fully on the N.EXT. (32mm on a wider id rim on the front, and 34mm on a slightly narrower id rim on the rear.)
I find it difficult to answer an objective question where there is nothing but experience and subject answers.
Getting tubes into a tubeless-ready tire is harder on the side of the road, which I learned the hard way last weekend.
Tubeless ready tires are a bit heavier than regular clinchers, I think.
see that’s what i am talking about. subjektive opinions.
as we can read here most writers agree on the difficulty of mounting tubeless tires. especially with tubes inside. and you gotta have a tube with you if you ride tubeless and live eg in a big city like me and most flats come from cuts - big ones - which no sealant will seal. so a spare tube is a must (or a call for a taxi).
otherwise i have seen online too many tubeless mounting explosions with sealant going everywhere. and living in an apartment and not having a garage or so for my repair and maintenance work i’d rather skip on having to clean my kitchen or living room from sealant on every single piece of furniture etc.
see
my answer above. i have listed all the known tube-type tire option with widest width available
I’m so dissapointed that Vittoria stopped producing the Corsa Control.
Yeah good points about 1. the thinking and commenting cognitive biases that apply in these tube/tubeless discussions, and 2. The downside/upside equation is unique to the user as you said. Rather than “one is straight-up overall better than the other”, if the user has unique or significant upsides (consistent rough/loose roads etc etc), then that, when weighed against the tubeless operational requirement and maintenance, can be an excellent investment. On the flip side if your roads are smooth and you somehow gets lots of puncture (if), then the tubeless argument changes again. Apologies if this is bleedingly obvious.:slightly_smiling_face:
People sharing opinions and experiences is not the same thing as getting objective answers. The reality is that the questions people ask quite often have no objective answers. Things like tire mass and tread thickness are properties that are objective. Rolling resistance? The Crr results for a given testing regime are objective.
Things like ride feel, ease of mounting, ease of setting up, etc are all subjective. Popularity polls don’t give objective results and even users reporting experiences with tubeless tires or any product doesn’t tell you anything objective.
So, do what you want . Not everyone is interested in that whole objectivity thing. FWIW, it’s not “as we read” it’s “as you read”. From what I’ve read here and other places, it seems experiences vary. I’m not going to pretend that all the reading, discussing, etc somehow morphed into objective conclusions about subjective things. I’m also averse to making up conclusions about how most riders do this or do that Again, what “most” riders do, like, hate, etc isn’t anything related to objective analysis. Valuing opinions is absolutely fine. Just don’t confuse that conclusive evidence of any sort.
Now excuse me, I have to get my tubeless wheels with their tubeless tires and tubeless sealant into the two ton iron cask in which I store them in the basement. That iron cask is there to protect my house and all the humans and animals within a few hundred yards of my house in case there’s a failure in one of the wheels. I don’t want to see anyone hurt or killed by a shockwave of vaporized tire sealant.
wow. thanks for your explaining. i feel enlightened. and passive aggressive seems to suit you well. anyway i am
just asking (hosting myself for) myself why i haven’t just posted a straight answer to the original poster’s question
There’s an objective answer to which set up is lighter. You might be able to get some way towards an objective answer as to which as the lower rolling resistance, especially if BRR has tested the combination you are interested in (although most of their testing of clincher tyres uses a butyl inner tube, so there’s a limited amount of data using TPU tubes).
However, it’s pretty much impossible to provide an objective answer to the question which is “better” because that depends on so many variables, including personal preferences. Where are you riding, how much do you weigh, do you care more about speed or puncture protection, do you enjoy tinkering with your bike, do you have a suitable space at home for dealing with potentially messy procedures, what’s the weather like etc.
Personally, I’ve been running tubeless on my road bike for 2+ years (longer on gravel) and am happy with it so far. There is definitely a bit more faff involved in the setup and maintenance, but I can do that in the relative comfort of my garage, at a time of my choosing. I have had a few punctures whilst riding, but as of yet (touch wood) all of them have sealed by themselves with minimal loss of air - I have spent no time stopped at the side of the road fixing a puncture. In the summer, or in warmer climes, changing a tube may be no big deal, but in the damp British winter, I am very grateful of not needing to stop.
