Crux Headset Compression Ring
FSA dust cap didn’t work, worked itself very slightly loose over 50km, 25km of that gravel. LBS noted that the headset bearing seat is probably slightly ovalized, the bearing can move slightly more fore-aft than side-to-side when disassembled.
Specialized came back with a warranty DSW frame offer, but I’m having doubts of whether the new one would have it fixed, as seen with the carbon Crux where it was an issue for 3-4 model years in a row. Maybe the Cane Creek BAA2471 or the FSA dust cap from the start would prevent it. And the warranty frame is a much much more muted color, almost a grayscale version of my current vibrant one.
There’s a second wildcard option - having the top bearing semi-affixed with Loctite. It’s a common procedure that has been done a lot locally, sometimes even preventatively, the bearing can be removed and replaced later.
Is your current frame damaged? If not, just do the Cane Creek BAA2471 - it fixes the issue (I have it on both my Cruxes). I would NOT recommend Loctite but then again I am not a bike mechanic. :wink:
I would lean on them for a new model Crux frame, arguing that you have heard that it’s an issue across all existing carbon & alloy frames.
The aluminum frame? Have the upper bearing seat reamed. The (new replacement) bearing will then sit square again.
Cane Creek’s headset did not fix it for me, though I’ll go with it for the new frame from the get go and hope for the best.
I went with the warranty frame they offered - 2025/26 Crux DSW. I’ve warmed to the color, it’s the silver one with yellow accents. Plus, a new frame is a new frame.
The Crux 5 has a massive wait list and first units will only arrive in September. In my part of the world, there is only S-Works frameset on offer and I doubt Specialized wants to replace my €1600 aluminium frameset with an incredibly in-demand €3200 full bike or €5800 frameset :joy: Especially as they plan to keep the DSW in the model lineup for CX duty.
New frame with BAA2471 from the get go is rock solid, around a 1000km of very shaky and rattly gravel with 0 issues and no loosening. The steerer was cut few mm shorter so the Cane Creek top cap could be used.
I would recommend to anyone to run BAA2471 on a fresh warranty frame from the get go.
Can someone please confirm that the Wolf Tooth IS42 non-specialized version works? I got a replacement specialized frame and am using the wolf tooth headset. I’ve done two gravel rides and the headset comes lose after each ride. After the ride, I can turn the headset spacers and bearing cover with my hands.
…isn’t that enough evidence that it doesn’t work, lol?
It’s either not properly adjusted to begin with (for various possible reasons) or the stem is slipping on the steerer tube.
What happens if you add extra preload? If the fork still rotates smoothly but with slight extra effort required, then the headset assembly is likely correctly fitted. If something starts dragging, then an extra spacer is needed, likely under the top bearing cover.
If the headset assembly checked out, after readjusting the preload properly, I’d focus on the stem clamp. Clean the steerer and stem clamping surface with alcohol. Remove the bolts and apply grease, anti seize, or thread locker, depending on what the stem instructions say and what your beliefs on the subject may be. Torque to spec.
Well, after a little bit of working fine, the Specialized replacement setup that they said fixed the problem came loose. Have ordered the Cane Creek and will get that swapped in shortly.
