I’m looking for a bearing tool set for replacing bearing is most common bycle wheel hubs and free hubs (most immediate need). Wheels/hubs I own: dt swiss 180 exp, tactic tr01, scope artech 4A, enve 4.5 pro. I see ceramic speed has a nice tool set but very expensive. Is there another option that is cheaper but can work with all the wheels/hubs I have and also be compatible with other modern wheels?? thank you!
Abbey tools fits a range of sizes. Bearing Pro Tools sells a set. Also, Dave Rome supposedly has an updated bearing puller review coming.
The Alt/Alt kit is ok for this kind of stuff.
Have a look at the Ztto press kits on Ali express if you need something a bit cheaper
Hi Robert,
Just in case you haven’t seen it, there’s an older Threaded article dedicated to this topic that should give you some specific tool sets to look into: Threaded #9: Installing cartridge bearings right
Related, I’ll be publishing a comparative review of hub bearing pullers later this week.
Bearing Pro tools sell each item separately so you can assemble exactly what you need as you need it.
