What to look for in custom geometry
Hi there,
I have long legs and a short torso and struggle with most bikes being too long and/or too low. This means with my current bike I ended up with a short stem, short reach bars, a stack of spacers and/or the redshift topshelf bars. I am considering going with a custom frame with a bikefit and would love to hear from people going through the process of getting to the custom geometry. What do I need to pay attention to?
I have spent hours comparing geometry chart and have some idea of what I think would fit but don’t know how that would work out in terms of ride feel.
I would like to not have any toe overlap and sometimes brush the chainstay with my heel, which I would like to prevent on a new bike.
Also, one of options I am looking at is No22 so any feedback there is also appreciated.
Thanks for your input, cheers
Personally, I think you should get your fit first, and not necessarily with the fitter of the custom builder. Normally, a custom builder is willing to work with fit data from another fitter or even from the customer.
That leaves room for you to search for a fitter that you have confidence in.
Second, search for a custom builder that makes products you like, that has sufficient experience with the type of bike you want (and the material you want it in), and that makes a really good impression when it comes to working together.
The builder should obviously be interested in:
  • the fit data
  • info on your weight, shoe size, etc
  • what type of rides you want to use the bike primarily for
  • the type of handling you prefer
  • the level of comfort you desire
  • other requirements, like toe overlap, gearing, tyre clearance…
Hopefully a productive discussion unfolds…
Just my opinion. Hope it can help.
Definitely go and get a bike fit first, and then ride with that fit for a few months to make sure it’s good.
From there when you work with a good reputable builder they will ask what you are looking for and concerns are. Are you wanting gravel, road, “all road”, bikepacking, etc, etc. That will also play into what they can do for you in terms of angles, lengths, components, and so forth. So if you tell them you want a gravel bike, but toe overlap is a concern, they’ll do what they can to accommodate this but understand there is sometimes only so much that can be done.
Ideally the builder will understand bike fit and ride characteristics well enough to work with your fit numbers, and not just slap you into the bar x/y and call it a day. The one I’m working with now listened to all my concerns, is working with them, and is keeping the bike in a modest geo as to not box me into the specific fit details I gave them.
Ive done 1 custom frame, and am in the queue for a second. The one thing I will offer here is they can feel both amazing and stressful. It’s an investment (especially a No. 22). You will be excited to get it, but also nervous about “did I do X right” or “should i have gotten Y”. They also may end up being a nuisance b/c of something being slightly out of spec. For example my custom steel frame is susceptible to slipping seatposts. It sucks and is annoying given the frame cost but i now have what works best, it just took some trial and error. At the end of the day just remind yourself its a bike and in 99% of cases you can fix the situation.
And a very important lesson- one I learned the hard way: think at the very least twice before making last-minute changes to your design. They may not be as thought-through as the original plan.
To add to what jack said, dont try to cram every idea into it too. My first frame I had it run with a dropper routing for gravel. I took the post out after a year, and now I have this unused port entry on the downtube. I can probably get it filled, but I need to wait for another paint job or just let it be part of the character of the bike. I also have rack mounts Ive never used once.
So much good advice here.
+1 to get a fit first, find an experienced builder, don’t try to cram in too many ideas / get too clever, think about whether you want to run the brake hoses through the headset or not (custom actually gives you that choice), and if it’s a 1 person operation take their ETA and double it :laughing:
I’ve done customs several times. I agree with all of the above. I will add: do not ask a builder to do something out of their routine (except Rob English, I suppose). Extreme example - don’t ask a tig welder to fillet braze unless they regularly do both.
You also - very importantly! - need to find a builder who’s on the same wavelength and whom you can thus communicate with. In some cases things are good, in others not so much. This is at least as important as the quality of their work, and there’s a much better chance of a successful outcome.
As Waltworks says on their website (paraphrased): “We need to talk before anything happens as one of us may decide the other is insane.”
A former coworker that worked a lot with custom bikes had a saying, “Custom bikes, custom problems”. I’ve seen a lot of issues with a lot of custom bikes - tires rubbing the frame and fork, despite the exact wheels and tires being sent to the builder prior to being built. Front derailleur clamp sitting right at the seat tube bottle cage mount when using the most common chainring sizes, and of course the misalignment and crooked brake mounts that are unfortunately also common with production frames.
With that said, if going custom geometry, I’d stick to the most popular, most reputable brands, and as mentioned above, stick to what they’re good at.
I’d also not entirely rule out the right production bike. An “endurance” road bike might fit the bill, as they tend to have a lot more front end stack. If needed, and with enough stack, you could even size down to shorten the reach even more. I’d be mindful of shortening the reach too much. With long legs, your knees need extra clearance to the bar. Whether or not to account for that would also depend on how often you expect to be sprinting out of the saddle.
Just food for thought
I think if someone finds a good customer builder, there aren’t going to be problems. If someone goes the custom route they should do their due diligence in when checking out builders in whom they’re interested. Of course customer builders can make mistakes, just as the big manufacturers can. The big manufacturers deal with warranty issues, and I think custom builders are typically pretty quick to correct in mistakes since their livelihood.
Of course not all custom builders operate on the same scale. My current bike’s frame was built by a custom builder, one man building frames, forks, etc. There are loads of male and female frame builders operating on their own or with another person or two. Other builders much bigger. They might have many working to produce a lot custom frames each year.
As for geometry, I think a good builder can produce a geometry that gives a give customer the ride qualities they want. Before my current frame was even ordered, I’d had a bike fit. Then the builder I had a long discussion, several discussions in fact, about how wanted the bike to ride, to handle, in the types of riding I described. We talked how the bike was at the time was lacking in some areas, but performed as I wanted in others.
In the end, I the builder produced a frame, that performed as requested. He also produced a frame whose disc brake mounts, BB shell, and head tube were properly faced. Alignment was spot-on. I’ve had the bike for 3 ½ years now, and still get excited every time I ride, and I’m still blown away by how the builder nailed the ride quality and handling.
YMMV.
I have 4 custom bicycles that span probably 30+ years. The last one is the best because I really knew what I was getting and the industry has become better at dealing with small women. Like you I have a short torso and long legs and that makes it harder to fit. I’m too small to ride any off the shelf bike.
Ideally you want a builder who really understands bike fit. My first bike was just a build and copied the basic design of an American frame builder (Georgena Terry). It ended up being still too long in the top-tube. The second bike was built to the design of a fitter who worked with the frame builder. As was the 3rd. Those bikes were both 650c wheels in order to get a fit for me. My last 2 bikes were built in Australia by Darryn Baum. The newest one has 700c wheels for the first time in my cycling history but that’s because things have changed with components that allowed that. Honestly, it’s the best one and having standard wheels is a game changer.
What I would also say is that there is a direct relationship between the amount of time the frame builder and fitter spends with you, the degree of customisation and the finish, and the amount you will pay. A truly custom bike is a high value investment.
Like everyone else says, get a good quality fit first and adapt your current bike(s). This will maybe fix all your problems and you’ll find out that you’ve chosen a bike by standover height when you should have been looking at top tube all along. But at least you will be used to riding in the correct position so when you do invest in a custom bike, you aren’t discombobulated by the position. You want to love that first ride.
Mmm, you might want to read the entire Pegoretti-topic. And that is what is generally seen as a reputable builder.
That aside, indeed, even with a bike fitter doing its job, you indeed need a builder that understands positioning a person on a bike.
In my view, you have builders that
  1. know how to work material, and take into account bike specific limitations, and create a frame
  2. know how geometry changes (including positioning) affect handling
  3. know the intrinsic qualities of the material they are working with and can use those so they can attain the desired stiffness/compliance in every part of the bike to give you the desired ride quality
Some builders are only capable of point 1. Few are really into 3. Whether that is important to someone may vary. But 1 and 2 are in my view essential, unless you are just rebuilding an existing frame, then you perhaps only need point 1.
Thanks for all the thoughtful replies, much appreciated!
I have gotten bikefits in the past, which is how I ended up with short stems etc. The current position works but hampers the handling due to the combination of a short stem and the topshelf bar. It could be a smidge shorter even but then I start worrying about hitting the bars with my knees. I guess the question is how high and short can you make the front end before you run into problems such as hitting the handlebars and introducing toe overlap. I suppose the fitter and/or the builder should recognise that?
Thanks again, cheers
Bike fitting aside, let’s assume you know what you want in geometry. I dipped my toe into custom first with Waltly, an affordable Chinese custom titanium builder. The process was more difficult than I thought and I learned many lessons which weren’t as expensive as a high rent custom builder.
I’ve since taken those lessons to my upcoming Forma, which I’m way more comfortable working with now from geometry and in terms of what to expect from the process. I feel better about my choices for what will be a much much more expensive bike.
This takes money and time, but I found it a good use of them personally.
If it was for me, and in fact it is for me, since I also have long legs and a short torso, I’d go with an off the shelf frame from one of the bespoke frame builders, Fairlight comes to mind, that offer frames in regular and tall sizes. You’ll save thousands of dollars, and get a fame that is thoroughly tested and vettted in the exact geometry your fitter recommends. These days OTF frames are so good! Spend the extra $ on the best wheels and group you can afford. And definitely get a fitting from a respected practitioner before ordering!
FWIW: I didn’t find Waltly at all difficult to deal with and expect I will do so again, however you must know exactly what you want, and iterate things until the drawing shows that; you need to understand and check every dimension! Waltly will build exactly what’s on the final drawing, so it has to be right. As they say, they are not bike fitters, so that part of things has to be sorted before talking to them.
Most other builders have their own ideas of how things should be, which could be a good thing, or not, depending. Various people specialise in various things, and asking someone to build something outside their area of exprrtise or interest isn’t likely to end well - if they’ll even consider doing it.
As was said above, custom frames can have problems, given every one is essentially a prototype. You may also find that frame #1 doesn’t quite hit the mark, but by #3 or 4 things should be dialled. Stock frames OTOH are fixed in design, and can be test ridden.
My first custom bike should be arriving shortly. I picked Mike DeSalvo because he’s been doing it for almost 30 years. We talked about what I was looking for, I sent him my fit data, and when my slot in the queue came up, he sent me a design that was exactly what I was looking for. I trust his wisdom on tube sizes, head tube angles, bottom bracket drops, chain stays length to accomplish the mission. Unless you have real strong opinions on things like that, it probably makes sense to find a builder who has done lots of bikes in your style and trust them.
Fairlight looks great but while the stack might work on the Tall geometry the reach is even longer than my current bike..
The tall geometries of frames are for regularly proportioned people that want to sit more upright. People with a short torso or short arms (like me) are often still in a racy or even too stretched out position on those frames. Possibly even with a very short stem and short reach handlebar. And if the trail number isn’t large enough, you get very twitchy handling with a very short stem, let alone a short reach handlebar in addition.
EDIT: Michael_F notices the same.
Oh boy, what a can of worms! I have several custom bikes by many different builders, including two No 22’s (Great Divide and Drifter). I have bikes in steel, stainless steel, Ti, and carbon. Lugged, TIG, filet brazed, carbon monocoque and carbon tube-in-lug. Custom means different things to different people I suppose. It could mean a made-to-order frame with a “standard” geo made by a boutique builder (like Moots, for example), alternatively you could start with standard geo frame and make some minor changes, or a fully custom/bespoke frame made from scratch from a boutique builder or a one-man shop. My No 22’s for example started with their standard geo and then I made some changes, such as a downsloping top-tube rather than a horizontal top tube to allow for additional standover clearance. Very happy with them and of course they can do fully custom. I purchased my first custom/bespoke frame, built by Stephen Bilenky, almost 20 years ago. I started with a Trek 5200 size 52 and copied down that geometry. Then I modified it based what I thought were the frame’s shortcomings. From there Stephen input his particular handling and design philosophies and then selected the individual tubes based on my input. All my frames since then have been based, more or less, on that design. At this point I can just send the builder a drawing and say “make this”.
If you haven’t had a proper fitting done and/or you are not really sure about what geometry you are looking for, then I agree that is the place to start. Choosing a fitter is almost as important as choosing a builder - perhaps more. Make sure it’s someone who can prepare a document for you containing all the desired measurements in detail. Even better if they happen to know the builder.
Picking a builder could depend on many factors. Do you want someone local? Or at least in the same state/province/district/department/region/country? Do you seek a personal one-on-one experience or a more boutique type experience? Hi, low, or medium budget? No budget?! I’m in the US where there are lots of one-person-shops as as well larger fabricators where the guy designing the frame may not be the one fabricating it. Are you looking for a specific material and/or tube-joining technique? Or a specific aspect about the bike like S&S frame couplers, gates drive, etc… So do you want a TIG welded Ti frame or lugged steel? TIG-welded steel? Carbon with a one-piece look…Argonaut. Carbon with a tube-in-lug design…Calfee. Chose a builder whose aesthetic pleases you, and who makes the kind of bike you are looking for. Bilenky, for example, is well known for his filet brazed steel frames (he is also known for his very long lead times). David Kirk is known for his work with Reynolds 953 stainless steel. Brad Bingham is known for the amazing quality of his Ti welds (which I can attest to). Is the quality of the finish important? Then choose a builder known for their finish work. Or be prepared to send it to a specialty paint or anodizing shop. There are some builders like Leonard Zinn who are known for their work in making custom bikes for big & tall people. Perhaps you are of a certain age and want something nostalgic? In the US Carl Strong, Chris Chance, Ben Serrota, and Richard Sachs are all kind of semi-retired but they are still making frames. Fortunately there are quality, experienced builders in all these categories with lots of overlap, so it’s hard to go completely wrong.
Good luck!
