Ultegra 8020 to Br-rs785 calipers - which brake hose to use?
Lol the “wheel stopper” is a box of matches I was a using to burn off the iso alcohol after lightly sanding the pads to to make sure they were fresh and uncontaminated. Forgot the were even there hah
Paint job is my own rattlecan fade, over chameleon masked leopard spots. I call her “Lisa Frank”
The levers are firm so the system is bled well enough in the sense it’s not spongy so it doesn’t feel like any air trapped. I’ll try the “single light pull” caliper advance trick if the travel doesn’t shorten up after a bit. Thanks again!!!
Any time!
PS. If you were using isopropyl alcohol, you wouldn’t need to burn it off, since it evaporates really quickly.
