Tip for tracking wearage
Hi! Listened to «Going back to basics» and wanted to mention Wearage, ‎Wearage App - App Store, an app that tracks wear for different components. Links to strava! Thanks for a great pod!
I think this must track time or miles, but how can it track component wear? Wear is a measurement.
From a technical perspective, think about that.
I use similar apps to track distance ridden, because it helps me then remember to check for wear (eg after X kilometers, start measuring your chain, or rotor thickness, etc). I think it’s pretty useful even if it technically doesn’t track wear, because most things wear at a pretty consistent rate in my experience.
The strava feature “my gear” does this pretty well already. I’m a free strava member and it works ok. It acts as a nice notepad to remind me to check my chain, tyres and brake pads once they have done a few KMs.
ProBikeGarage is a similar app, but development has been seemingly dormant for nearly 2 years
I’m the boring one that just uses Excel.
I track all maintenance, miles, time between service, time between failures, rides, etc..
Provides everything that I need.
If you have only one bike and one set of wheels and rarely swap any components, then the gear tracker in Strava will probably suffice. I have been using ProBikeGarage on iOS for several years and other than one unexplained extended outage that had a lot of its users worried, I am generally happy with it. What I would like to see in PBG is the ability to produce reports on components, for example a graph comparing the mileage on all the retired tires, or battery life, etc.
As somewhat of a power user of PBG (Android here), I completely panicked when that outage happened. I messaged the devs and promised to pay for premium if they brought it back. Now as a Paid Subscriber, I’d love to have access to a reports function, as you say. That is a great idea.
I love the idea, but I cannot download the app in my location (EU, Germany). Is that an intentional choice? If the app does what it says on the tin, I’d be more than happy to pay for it.
(I have downloaded a few of those apps, and most seem to be money grabs and/or force me to share all sorts of info with third parties.)
Wow, based on their screenshot Wearable looks like a near direct rip-off of ProBikeGarage:
(PBG is maybe a little more generic, no “Wax/Lube” switch on a Chain etc. but the UI styling is even the same!)
No limitations to what you want to see in Excel.
Pro Bike Garage requires an active Strava account. I have made a conscious decision to stop using Strava after one too many of their shenanigans. So if this app were like Pro Bike Garage, but without having to use Strava, that’d be more than fine with me.
Intervals.icu lets you track just about any component of your gear you can imagine. Highly recommend.
Intervals.icu is great for the training load tracker. Especially as it’s a free alternative to Training peaks and Strava subscription. I didn’t realise they had a gear tracker. I’d encourage others to check them out and support them if you fancy.
