Look towards the horizon…there are better opportunities for us. But this isn’t one of them.
Stans sell thir own injector and theirr website says
"Stan’s Tubeless Sealant Injector
- 150ml capacity to fill all tire sizes
- Press-on, drip-free adapter ensures clean and easy use
- Hang plug provides clean storage
- Compatible with Original and Rolled Gold formulas
But not compatible with Race Day sealant.
For some reason i thought stan’s advised against injecting rolled gold, but clearly i was wrong!
(worst of all, i’ve let MYSELF down
I need to pop the bead to check the level anyway (reserve fillmore valves) and wouldn’t top up without seeing what is there already.
Simon
I injected Rolled Gold a few weeks ago into a fillmore valve. Works fine.
@user188 Good to read. But how do you check the level of current sealant without popping the tyre bead. I guess you can shake the wheel to see if any noise, but open to a better idea.
I would love a good method. I don’t have one, especially since I moved to Fillmore valves.
i check every 4 months by shaking the wheel.
To check sealant level in your tire you could just remove the valve core and probe the level with a toothpick, wooden skewer or similar.
Ps: Oh you guys with Fillmore valves can’t do that, sorry.
Sealant level is one of those items that gets confirmed at least on a monthly basis for me.
As such, ease of accessibility to validate levels is a personal consideration. Popping beads off to validate sealant levels seems inconvenient. I tried the Filmore’s several years back and felt they a bit fiddley and I never had air flow issues with traditional prestas.
This is my sealant Dip Stik. Small enough to clear stem ID to bottom of tire for an accurate reading of level.
With my various tyre / rim combos i’ve occasionaly had issues with getting a tyre to seat using regular presta valves and switching to fillmore resolved that. But the 10 minute faff to partially dismount tyre every 2 months is something i can live with. Especailly as i’ve always found them needing a top up but never totally dried out. With a BBB cheap plastic tool and the vittoria airliner tool, the tight tubeless tyre thing is manageable.
Whatever works!
Were you removing the valve core?
Of course - always removed the core!
I can’t remember the rim / tyre combinations which gave me hassle but i was rubbing washing up liquid onto the rim multiple times with lots of stress.
Then I’m assuming that you were using a floor pump and not a compressor?
I don’t usually have issues seating road tires with a floor pump, but the compressor never fails to seat everything.
Yeah blast type floor pump with a tank. Aside from seating tyres, regular inflation also easier with Fillmore compared to presta. But it’s the seating of tubeless tyres that encouraged me to try them
The faster flow rate with the Filmore’s was a positive factor, but I ride almost daily and the near daily amount to inflate was usually minimal.
A bit of thread drift, but on the topic of inflation. I have gone to almost exclusive use of a battery inflator for daily or bike stand use. The compressor still sees other shop work, and the occasional seating of challenging tires. Not so much as it used to perform.
I know it varies depending on tire choice and rim, but I’m able to seat Conti GP5000 S TRs on Reserve wheels with just a regular floor pump.
