I recently got my bike back from the workshop and noticed that the rear brake pads had been replaced with a different compound (OG organic replaced with sintered) than before. I’ve already ridden about 400 km on the new pads and haven’t noticed any obvious issues so far, so not worried, more like curious.
SRAM recommends replacing the rotors when switching between pad compounds, so I’m wondering how strictly I should take that recommendation. Is replacing the rotors really necessary, or is it more of a best-practice recommendation?
I also tried looking for similar guidance from Shimano but couldn’t find anything suggesting that the rotors need to be replaced simply because you’re changing pad compounds. Their documentation seems to focus mainly on rotor and pad compatibility.
So, I’m curious about your real-world experience: Have you always replaced your rotors when switching between organic and sintered pads, or have you simply kept the existing rotors without any issues? Did you notice any differences in braking performance, noise, or pad life?
I’m especially interested in whether anyone has run a different compound on the same rotors without problems.
I’m also wondering what I should do when it’s time to replace the pads again: assuming we agree that I can keep my current rotors, should I stick with sintered pads from now on, or can I safely switch back to organic pads without replacing the rotors?
Replacing your rotors after 400km seems like less then ideal.
It depends how much you wanna stick to the best practice.
I have swapped compound during a bike trip because it was the only pads available and it took a couple of days to get the disc to stop squealing and bite at 100% but they eventually did. Careful braking and avoiding glazing is key though.
Next level up in my personal experience is to thoroughly clean your discs, sand their braking surface gently and bed the pads in with care. It has worked most of the time for me.
Professional level: swap discs and put new ones on.
I’ve swapped back and forth between sintered and resin a few times without changing rotors. Ideally, I’d recommend wiping the rotors down with isopropyl alcohol and then some light sanding with fine grit sandpaper.
Personally, I think this advice is unnecessary and not required. I have been maintaining bikes and brake systems for many years and I find this suggestion just a marketing thing. I have never experienced any braking degradation by changing pads, cleaning rotors and assuming a proper bedding process has been completed on existing rotors.
A good example and reason to consider servicing and maintaining your own bike.
It’s just a good reason.
There are plenty that have no interest or time to maintain their own ride.
A follow-up question regarding the purchase of new brake pads: is there any other difference between aluminum and steel backing plates besides weight? What about heat management?
Neither is an issue for me. But my question was whether there are any differences between aluminum and steel backing plates in any respect other than the obvious difference in weight. No? Good.
Shimano is the manuf that stipulates different rotors for sintered vs. resin. I’ve seen no such stipulations from SRAM. That said, any shop worth their fee schedule will clean rotors (we use acetone) and freshly bed after pad replacement. Selection of sintered vs. resin should be an intentional and functional choice.
Shimano rotors RT-64, 66, 76 or RT800 can use Metal or Resin Brake Pads. No pad restriction.
Only these Shimano entry level rotors have restricted metal pad use, RT-56 & RT-26 can ONLY use Resin Brake Pads (No metal pads). The pad restriction is stamped on the rotor.
