Recently switched from 80mm reach Easton bars to Teravail Radia (Salsa Cowbell) to try and bring the controls to a more natural hand position, but I’m not loving the ramp on the bars. It seems like any bar under 80mm that I can find has this same issue where the control location requires the bars to either not be level and/or running the controls more up. Both of which I find feels like it reduces the reach even more (even after a longer stem).
So just trying to see if anyone has found 12-16 degree flare bars with flatter tops compared to your Zipps, Salsa/Teravail, Ritchey’s of the world. I thought Deda might work but they have the same issue where the ramp is pretty steep.
These are with Sram D1 controls, if that helps.
