Hi folks,
I’ve set up my gp5k str on zipp 404 FC with vittoria air liners with no issues (challenging yes but done). I’ve now switched the tire from 30 to 28c same brand due to frame fit issues. This time when I inject orange sealant using a steel needle (similar to the park tool injector), most of the sealant squirts back out. I try to move the liner over with my hand but it hasn’t worked. I’ve cleaned the valve stem out and there are grooves at the top of the valve stem (inside the rim)which would allow sealant to move past the liner. Anyone else run into this issue?
