Road Frame Tire Clearance - 2017 Specialized Tarmac SL5
I am getting ready to do some riding in Belgium on some of the cobbled climbs in Flanders. The bike I’ll have with me is a 2017 Tarmac SL5. I am pretty sure it can handle 28mm, but am wondering if I could use 30mm. Specialized does not seem to list the max tire width for this frame. Does anyone have an idea of where I could get this information, and are there any recommendations for the tires to use? The wheels are Roval CLX 32s.
The problem may be the brakes. Most rim brakes can’t fit a tire larger than a 28.
Hi Scot, I have a rim brake SL5, and had this issue firsthand when I upgraded to 25mm rims and 28 tires. I originally used specialized roubaix 28s but the rubbed the frame and top of the rim brake housing. They were incredibly comfy though…
Then I switched to bontrager r2 28s and they fit way better, with perfect clearance. They are sadly not as comfortable, but better than 25/26 tires.
I would try the r2 or r3 28s and run 75-80 psi. Safe travels!
