Repair stand for deep aero seatpost
Hello all,
I have a new aeroad with a fairly deep aero seatpost.
I currently use a feedback sports mechanic stand where the clamp really does not even work with smaller aero seatpost (but I get around this by clamping front-back instead of from the side). However this won’t work with such a deep seatpost now.
I’m wondering what my options are for a repair stand solution now:
  1. Feedback sports sprint stand - or similar style (any other suggestions here for better alternatives?)
  2. Silca hirobel adapter
  3. ??? Another option I’ve missed
Thanks!
I have the Silca Hirobel adapter and it works really well. For simple tasks - e.g., relubing chains with Silca Super Secret drip wax, hand wiping my bikes down, etc. - I don’t even use the rubber straps. I just put the bike on the adapter, and it stays in place, which makes using the Hirobel when swapping bikes much easier than a seatpost clamp style repair stand
+1 for the Silca Hirobel if you want to stick with the Feedback Sports Pro Mechanic Stand. This has always been a shortcoming for that clamp head style. If you are not married to Feedback, the Park Tool stands work great with any aero seatpost. They even have a rubber insert for those cases where the back of the seatpost is flat.
A lot of good feedback here (mine included) for the Hirobel though for a slightly different use case: How to clamp bike in work stand when exposed seat post is too short - #30 by David_Cifelli
What’s similar though is not clamping the seatpost, which the Hirobel is perfect for. I will say a bike in the Hirobel can rotate under heavy torque (think BBs) but it’s manageable
+1 for the Feedback Sprint stand. So many bikes, and I still get unnerved clamping a carbon bike by the seatpost, seat tube, top tube (using a Hirobel), etc. One tiny crack and one displeased client later, and that’ll be the end of things.
Downside for the Sprint stand is the need to undo one wheel (and inserting the caliper spacer block). But at least the weight of the bike is supported at locations reinforced to bear significant weight.
Hirobel does not clamp onto the top tube. The top tube rests on two “paint safe” cones and there is one strap per cone to hold the top tube in place. I don’t do any high torque activity like tightening a SRAM crank bolt while the bike is on the Hirobel.
Here’s the cheap version, using drop bars as a substitute for the Hirobel:
Take an old set of metal drop bars
Put bar tape on them, wrapping as far towards the center as possible
Turn your bike stand clamp to horizontal, with the non-moving part of the jaws facing down
Clamp the center of the bar into the stand, with the ends of the bars pointing up, creating a cradle. This is your makeshift Hirobel.
Set your frame into the bars. You can add a couple of used tubes or soft straps to secure the frame. I don’t bother with that and just don’t do anything requiring a lot of force while the bike is in the stand.
What style of clamp do you have on your Feedback? I upgraded to the Pro Mechanic clamp on mine and really like it. I have a Pinarello Nytro with an aero post that I ok with clamping the post as the jaws hit the edges of the post, plus I do not clamp it extremely tight.
I also use the handlebar method on my Park Consumer stand from the mid-90’s. That clamp is really not designed for carbon fiber or weirdly shaped tubes.
I’m really happy with the Parktool PCS 10.3 with my Aeroad
