RE: Moving dropouts from Ask a Wrench
I might have an alternative solution for the dropout problems mentioned recently. The caller should try another wheel to see if this fixes the problem. We had a CX bike do this recently when we switched wheels. The prblematic wheel had lost a spacer that threaded onto the outside portion of the hub axle. Luckily I found the part in a bin and the wheel worked perfectly afterwards. Good luck!
