I’ve got an older FC-7900 Shimano crankset. Is there any reason (besides aesthetics) not to run one of the newer one-sided powermeters on that, a 4iiii or the like? I can just change the right-side crank and I’m good, right?
Someone asked this a while ago about a specific SRAM powermeter, but I thought maybe there’s some-brand specific considerations here?
Shimano cranks all have the same spindle profile so generally you can just swap the non-drive side crank arm.
I would advise checking the Q factor for the crankset. I gave myself a repetitive motion injury partially from running an older ultegra crank arm on a GRX crankset because they have different Q factors. I’d imagine mixing and matching different gens of road cranksets to be less of an issue.
I have been running single sided power meters for years and recently switched to double sided pedals. I will never go back.
My old power meter was reading at least 30 watts high (at FTP) and I’m reasonably sure this was due to a L/R imbalance. I’m actually pretty sure that the imbalance was caused over the years by the single sided power meter. I think that I unconsciously focused on my left leg because it resulted in more consistent power.
Long story short, spend the extra dough and get a double sided power meter if you want to use one.
And - I know you didn’t ask but others are giving you free advice too! - I have both single and double sided PMs, and I’d probably just go single sided again next time and save the $$. I know there’s a discrepancy between my L/R balance but for my very average punter racing I don’t think it’s enough to worry about.
Re Q factors: Pretty well all 2x HT road cranks prior to 12 speeds have the same Q @ 146mm. 12 speed are 148mm, so 1mm difference each side, most likely unnoticeable. GRX are outliers though at 151mm; the difference is a bit larger, and some will care while others won’t. I’d be more likely to use a non-GRX LH crank to cut down the LH Q due to an old injury, but YMMV.
I’ve been using a single-side crank power meter for a few years, but having just bought a smart trainer I’ve realised the crank has probably been reading high. I’m left-leg dominant and the crank compared to the smart trainer is 20-30 w higher. When I get out of the saddle, the difference becomes much smaller.
How do people deal with data inaccuracy and inconsistency? I’ll continue training outside with the crank power meter so just forget about the difference and use it indoors as well? Invest in double-sided power for the bike?
Everyone’s different. I started with a double-sided power meter pedals and quickly realized that any difference in my L-R balance was probably well within the margin of error, so personally I have had no regrets in taking advantage of the lower cost of left crank only PM’s to equip the rest of my bikes with them.
The dual-sided pedal-based power meter was useful when I had to come back from injury, but my L-R balance came back quickly even from recovery for a broken hip. Again - everyone’s different!
Go by feel and use the power meter to back up that feeling. I used to aim for a zone rather than specific number when I had a left-only power meter. With dual-sided pedals, I can aim for a tighter band; it feels better to my monkey brain, but it’s hard to say if it’s objectively better at my level of riding.
If you train indoors, use your crank as your power source and your trainer as the controllable resistance device. This won’t solve your imbalance, but it’ll be easier to complete your intervals.
My L/R balance shifts significantly depending on circumstances. I’d definitely want to get a power meter that measures total power (like a spider-based power meter) or a true L/R power meter (pedals or some crank-based power meters).
I’d also second/third the suggestion to get Assioma pedal-based power meters.
Power meters are often wildly inaccurate. Don’t assume the discrepancy is due to L-R imbalance. I know people who dual record for online racing and it’s a common issue.
In my view power meters provide information to compare your training progression on that power meter alone. I.e. did you make more power today than yesterday? Trying to compare across different power meters is probably useless.
