In the past, I made a habit of switching between Chamois Butt’r and Udderly Smooth, because if I used one for too long, I would end up with a reaction. If I did one tube of Chamois Butt’r, followed by two tubes of Udderly Smooth, I managed to avoid any issues. Recently, I can’t seem to source Udderly Smooth in the UK. I’m looking for another cream to sub into the rotation. My only real requirements are 1) that it’s different enough from Chamois Butt’r to be worth switching to, and 2) nothing in it beyond what’s necessary for anti-friction, so nothing that causes any cooling, tingles, etc.
I should mention - squeezy tubes preferred, but I’m willing to go with a tub if I have to.
Does changing formulas with the Chamois Butt’r make a difference? I’ve used the coconut with no issues.
I found DZ Nuts Chamois Cream pretty good, but I don’t normally uses it unless I’m doing real long days.
I can’t take credit for this revelation (thank the discord user known as Anna R) but I’m a convert to the principle that the only chamois creams worth using are ones which aren’t water-based. This is a pretty short list - I’m currently on Squirt Barrier Balm. I wouldn’t say I “like” it (it’s kinda unpleasant to use) but it’s the first chamois cream I’ve tried that is still actually doing something useful at the end of a long ride
