Modifying EP8/EP6 settings on Project E-Tube
I have an Orbea Kemen ADV e-bike that was purchased in Canada and is factory limited to 20kmh. I’d like to change the speed limit rating to class 3 by either changing the region, or the speed limit itself.
I also hope to install a di2 linkglide group via sd300 cables to the motor interface. I believe this will require enabling the functionality in the EP6 software via etube project.
If I install project etube professional on my PC and purchase the SM-PCE02 PC interface, can I make these settings or is there more to it than that?
I think there’s more to it than that. A good resource for this type of info is emtbforums.com. You’ll probably find answers there (there is already a lot of discussion on this type of topic there), and if not, I’m sure a new post would elicit lots of good info.
Thanks for the reply! I will get into the weeds of the eeb forums
