Is there something like REALLY waterproof overshoes but not velotoze?
I have some Specialized toe covers right now, have used others is the past. The stop the wind and have a bit of insulation. For socks I am using 7Mesh Merino wool, would call it medium weight.
GripGrap spatz are the cheap neoprene version of these. Next to skin and then over the top of overshoes or winter boots and there’s no leaking of water down your leg into your sock
I gave up on overshoes/booties and use waterproof socks. I have merino lined lightweight CrossPoint brand. Work very well, but you need enough room in your shoes for them
I use a pair of POC’s thermal booties for my wet rides above 8°C the OP mentioned above. If it is too cold though they don’t keep me warm enough and I end up using winter shoes. POC has a heavy duty version that is supposed to be warmer, but I haven’t tried them. Black linked here, but also come in the POC orange (20% off available through the member purchase program): https://poc.com/en-us/product/thermal-bootie-uranium-black
I’m not 100% pleased with my winter shoes, but they end up keeping my feet warmer than the booties. I haven’t used them in really wet weather. When it’s that cold and rainy, I opt for the indoor trainer.
I’ve tried waterproof socks once, but my feet froze. I think they were too tight/compressive and restricted circulation. I need to get a different pair, not so compressive, and try again I think.
I’ll also add that I ride with fenders in the winter. Many benefits and cutting down on the spray from tires to your feet is one of them.
Instead a neoprene cuff worn next to skin and over the top of the boot or waterproof sock is the answer. Grip Grab sell a pair very reasonably priced and they work really well!
Nothing is REALLY waterproof. It will get in eventually. having a good set of mudguards is usually the kicker that will help keep you drier for longer.
From my experience they are better so maybe my shoes were simply better to begin with?
Hi, also from Vancouver BC. I’ve tried quite a few things. Most recently, I’ve been using summer shoes with thicker wool socks and some Grip Grab winter neoprene shoe covers. I just pull my bin rights over the air covers and that does a fairly good job at keeping the water out. In a true downpour, I will wear fully waterproof cycling pants that go over my overshoes, but that only works below about 5C.
Thanks for letting the question. It’s a tough one!
