Pretty self explanatory. Anybody know any integrated bar/stem setups that will fit an SL8, that are on the narrower and shorter side? Like 35 cm centre to centre (ideally) with a 90 mm stem? Have looked at the usual suspects, and bupkus so far. No for Enve, and no for Roval. Even some of the exotics (Gemini) don’t come narrow enough. Anybody?
If you’re not opposed to established Chinese brands, EXS has its Aerover Integrated that’s available in a wide range of sizes from 360mm (tops) and 380mm (hoods). Not exactly 350mm, but close. Stems lengths are available as well.
Why not go two-piece with an Enve bar?
Aesthetics.
I will if I have to but I would rather find an integrated alternative.
Take a look at Panda Podium. I see a 36/90 listed there.
FWIW, a “38” Roval is actually 36.5 c/c at the hoods.
Really? Do the “40” sizes actually measure at ~38cm c-c then?
Haven’t measured one, but perhaps 38.5?
I have an uninstalled 110x40 Roval in hand right now. So it seems they measure 40cm C-C at the further point in the drops where you’d also measure bar reach from. At the hoods where they typically clamp, it’s about 4-5mm narrower C-C, so about 39.5cm. Definitely not 38cm.
