Home Truing Stand?
Ok, what are your opinions on home trying stands?
The Feedback Sports stand (Pro Truing Stand 2.0 - Feedback Sports) looks ok but not great for radial truing.
Curious what people have done? I am not sure I’m willing to drop $400 USD for a professional grade one.
Open to suggestions!
Personally I would shop the used market for the shop level Park stand. There is always someone out there who bought one for one or a few builds and is then selling it.
Roger Musson has instructions for a wheel truing stand in his book: Wheel Building and Spoke Lengths for cycle wheels, don;t know how well suited it is for radial lacing.
I have a home made Roger Musson truing stand and it’s good enough for my occasional wheel building. I also have the Feedback Sports one which I use for some jobs where I want to spin the wheel (e.g. putting in sealant) or need a basic lateral truing.
The home made radial truing gauge would work fine with the Feedback stand as well. It’s just a flat edge on a wooden base that you can use to figure out where there are high or low spots while spinning the rim.
I haven’t really felt the need for a fancier stand but then again I don’t build wheels that often.
Years ago I started with a cheap model from Performance Bike, nearly useless. I bought the feedback during one of their annual 20-30% sales, and love it. It packs and stores small, is solidly built, very easy to work with. I especially love that it can true rotors too, which is actually where I’ve used it most. I’m mainly a roadie and wheels stay true, but the rotors often get slightly bumped out of true and I can’t stand even the tiny scraping sound of wasted watts.
Depends how much you think you’ll use it - I’d only pay big $ if I knew I was going to be building a few wheels, otherwise for a couple of builds and a few true-ups then almost anything will do. A nice stand will improve speed and efficiency but it won’t necessarily make the result better - that’s largely a matter of skill.
Back when everything I owned was QR axle, I made some stands out of a chopped up hard rubbish bike (rear triangle and forks). Works well enough for me with some cable ties for runout gauges. I just clamp them in my bench vice when needed. That and a spoke tension gauge, and some good nipple tools, are about all you need.
I ponied up years ago for a park tool TS 2.2 (ableit with an industry pro deal)… I can see the value to use ratio being favorable for the Feedback Sports stand, though
I tried looking for a used park tool for years (lost bids on a few) and finally gave up last year and got the feedback sports. It’s probably the “right” tool of those available for the job, but I think the market could really use a half price park tool clone.
Pros: very compact, solid base, works well enough for radial/lateral/rotor truing. Seems like any wheel diameter / width will work (haven’t verified, but plenty of room with a 29x2.5 tire on and no real minimum).
Cons: doesn’t work well for dishing, especially QR. You can’t just flip a wheel with QR, you also have to flip the skewer so the lever stays on the side with the “drop out”.
Small nit picks: I feel like the probe used for radial truing could be a couple mm longer. It’s nearly falling off the main price in use.
The probe is solid when clamped, but moves a little up/down as you tighten the clamp. Makes it hard to get it exactly where you want it first try. Usually I get close the first try, then have to adjust up/down slightly if I want it perfect.
Through axle adapter feels high quality, but on at least a couple wheels with “loose” end caps, it seems how it clamps to end caps only makes the wheel sit 0.1mm(ish) lower than perfectly centered. Park tool might have the issue.
I shelled out for the shop level park tools stand and have been very happy. I’ve built 2 sets of wheels, trued a bunch of wheels, and rebuilt a friend’s front wheel after he killed the rim by hitting a curb. It will last me the rest of my life and hopefully continue to build wheels for whoever buys it in my estate sale :laughing:
No experience with the stand the op listed but if you like tinkering a nice stand is worth investing in.
