Crusher in the Tushar 2026…any advice/tips?
Hi
I’m travelling over from the Jersey, Channel Islands for a US holiday / this race. Has anyone completed it, any tips, recommendations….warnings? Obviously I’m coming from sea level so I will just have to survive the altitude and heat. we arrive literally 3 days before race day so no acclimatisation time at all, I’m competitive for my older age (48) but will be reigning it in just to complete/survive.
Any suggestions on bike gears (I have a 1x Factor Ostro Gravel), tyres size/tread (i can fit max 45 in the rear). Nutrition, should i race with a hydration pack, too hot/too much added. weight, unnecessary? I could just use 2 (or 3) x big (950ml or 750ml) bottles on bike and then aid station nutrition (not sure what is on offer) I have no idea how long this is going to take me. Pretty excited for the challenge though!:zany_face:
Thanks all!
Nick
I know a bit about the race, including having seen it livestreamed, but I haven’t ridden it. I was going to guess something along the lines of what Claude says … but Claude says it better (and there’s nothing I disagree with):
Great questions — the Crusher is a brutal, unique event and the gear/tire choices matter a lot. Here’s what the evidence says:
1x Gearing
The overwhelming lesson from racers who have done the Crusher is: go lower than you think you need. The Col d’Crush is so hard that even experienced racers found their gearing wasn’t enough.
The race founder himself has weighed in directly: the key piece of advice is to make sure you have at least a 1:1 gear ratio for the climbing — in other words, a cog in the back that is at least as large as your chainring up front. He personally runs a 1×11 setup with a 40-tooth chainring and an 11-42 cassette, which gives enough range for climbing while still allowing him to pedal at 35+ mph on the flatter sections.
For a reasonably fit amateur, the clear consensus recommendation is a 40t chainring paired with a 10-50t or 10-52t cassette (if running SRAM Eagle or a mullet setup). Having the extreme low end of a 52t cassette was described as “nothing less than a lifesaver, several times during the day” at the Crusher, and over the paved flat sections a 40t chainring with the three smallest cogs provided ample top-end speed. If you’re running a standard gravel cassette topping out at 42t, a 38t chainring is the safer choice for an amateur to ensure that 1:1 or better ratio.
The key point: the first year one racer ran a 36t front chainring with an 11-28 rear cassette and found the gearing was not enough for the Col d’Crush — his 2017 setup of a 40t chainring and 11-36 cassette was the result of that trial and error. An amateur will want even more range than a pro.
Tire width
Tubeless tires of 38c or higher are a must at the Crusher. Skimping on tire width could mean a very long road trip ends in a very short bike ride — riders would do well to err on the conservative side.
The sweet spot for amateurs is 40–42mm, run tubeless. Some pros run a 43mm tire on the front for extra cushion on the brutal washboard sections, while sticking with a 38mm on the rear — a mixed setup that prioritizes front-end stability and comfort on the descents. For an amateur who will be on the course longer and suffering more on those descents, going 40–42mm all around is the more sensible call.
In summary: 40t chainring / 10-50t or 10-52t cassette, and 40–42mm tubeless tires — and don’t second-guess yourself into going smaller on either.
awesome Nick! I live in Salt Lake City and have ridden the Crusher. Great race, you are going to love it.
I would run your 45’s, it can get pretty rough in sections, and the big descent is ripping fast. You will be happy to have traction and cushion. The pavement is really 2 segments and they aren’t necessarily key sections so you won’t be limited there (first miles from the start, and the flat across the bottom of the valley in the middle of the race)
The climb back up that big descent, Col de Crush, is steep and you will be super happy to have a nice climbing gear.
The Sarlac Pit for me was the gnarliest part of the race. It’s where the climbing start out of the bottom of the valley. Doesn’t look bad on paper but it is usually the hottest part of the race and it’s a dirt road where it can be hard to get a good rhythm going.
Thank you! I hadn’t thought of doing this, really helpful, I was conceding a 40t with 10-50 so sounds like that might be the best choice And as Ty suggests I think I’ll run my 45s..comfort for a long day!
Cheers Ty, great inside info! We move onto Park City for a few days after the race, hopefully have a few rides there and pop to SLC as well!
