Build thread: Waltly 3D printed titanium gravel bike
The tube angle thing took a while to unpack. First, Waltly said they could only do a 130 mm HT with no explanation. Since my desired stack and reach needed something around 100 mm, it was too big a compromise for me, so I dug deeper and lost about a week going back and forth. Finally it was explained that the shorter head tube required top tube and down tube angles that they could not make - again they provided no reason, but I suspected the modeling and strength validation they did was only within a certain range, and my geo was outside of it. I revised my geo by increasing BB drop, raising stack a bit, and lowering the top tube angle (I had initially wanted completely level). I also pushed them to get as short a HT as possible and ended up with a 110 mm with reasonable compromises on my starting geometry.
Waltly does allow for a lot of flexibility, don’t get me wrong, but because I wanted a very long and low bike I fell outside of that. I think the vast majority of people will be fine. Had I gone for a standard welded tube model without 3D printed components, I would have been able to get exactly what I wanted.
The frame quality and finishing was good. I measured things (imprecisely) with measuring tape and everything was as it should’ve been. Brake calipers were easy to center, so the mounts were flat enough on both frame and fork (supplied by Waltly but made by another factory). BB is also good, installation was fine and nothing strange so far on the few rides I’ve done. Headset bearings popped in just fine too.
I did notice two tiny pinholes at weld locations. I notified Waltly and they said it wasn’t a big deal. With these 3D frames, they very likely sand the welds down to get that smooth finish, and the pinholes get exposed as tiny voids in/around the welds.
The blasted finish looks great and is what I wanted. It’s of course more difficult to keep clean and marks up very easily, but being a Moots guy I’ll deal with it. I do wish Waltly cleaned the frame up a bit more after blasting though - it arrived covered in a thin layer of blasting sand.
Thanks for this thread. I’m working on a custom with a local builder and the timing of this was great.
My back hurts just looking at this bike. I would need a couple of years of yoga to ride this, but it’s a sweet build.
Super helpful, thanks Drew. Likely going down this road myself, I’m now inclined to consider a blasted finish! My geometry will also be ‘abnormal’, but in a different way that sounds like it should be within scope for the 3D printed parts :crossed_fingers:
Happy to help! Let me know if you have any more specific questions. It’s a big leap doing something like this versus getting a bike off the shelf
Hi Drew - just looking at your headset top cap. Looks like it’s FSA, and Waltly sell FSA h/s, but doesn’t look like they sell a zero stack version like yours (which looks very cool) - can you please share where you got that from?
Yup - it’s the FSA No 55R LS (low stack): NO. 55R 1.5" ACR LS – FSAProshop. It’s not widely available (previously OEM only) and almost all online listings show a photo of the regular 55R with a taller headset cap, which is misleading.
I bought mine from Bike-Discount but they don’t have it anymore.
Did you ask why there were angle constraints with the 3D printed junctions? I would have thought it’d just be a matter of tweaking things in CAD, and that the only limit would be minimum head tube length depending on the tubing diameters.
Also, you said the tubes were thin - do you know what wall thickness, and if they were butted? Thanks!
FWIW, I got a welded gravel frame from them several years ago, and it came out exactly as per the final drawing; there was quite a bit of back and forth involved.
I did ask but never got a straight answer and didn’t want to waste more time getting to the bottom of it. They would only say the tube angles were no good and even reflected that in their drawings which showed a slight kink where straight tubes connected to the printed parts. My suspicion is that their 3D designs were tested only within certain parameters and my choice of a really short HT complicated things.
I’m sure a traditional welded tube frame would have much more flexibility in geometry
Tube thicknesses were 0.9 mm throughout. I doubt they’re butted.
^ Very mysterious…
Their default tubing is 0.9mm plain gauge, which is what I got but it was a bit overkill, atiffness-wise., in the diameters they recommended: 31.8 ST, 31.8 ovalised TT, 38.1 DT, 16mm SS. They will now do butted tubing supposedly, but there are no details on their site of what they have.
