I’ve have Avid Elixir discs/levers on my MTB since new (2014?). They’ve been decent, minus a hiccup or two. I had the LBS replace the pads and DOT fluid a while back and finally took the bike out the other day. It was hot - 90+ - and halfway around the pads started dragging. This has happened in the past and I understand it’s a ‘thing’ with this brakeset.
My question is, can I replace the levers and fix the problem from coming up again? Or should I just bite the bullet and go with a new or decent used brakeset?
