11speed cassette compatibility
Hi All, am I correct in thinking that Shimano and Campagnolo cassettes of the 11speed variety are compatible? I’d prefer to no have to buy a whole new freehub for a set of wheels if this is a straight, no major compromise swap.
AFAIK only SRAM and Shimano 11-speed cassettes are cross compatible with one another. I’ve run a SRAM 11–32 11-speed cassette on my previous road bike that came with a 105/Ultegra drive train. That worked perfectly.
Campag to my knowledge uses a different standard. 12-speed drive train components are no longer compatible, though.
The spacing at 11-speed is close enough to work. I used to have a customer who ran 11-speed Super Record, but used Dura Ace cassettes because he liked Shimano wheels (and they don’t offer Campagnolo freehubs).
I believe Campagnolo vary the gap between some of the sprockets as you move across the cassette, which Shimano don’t, but how much you’ll notice I don’t know.
Usually 1 or 2 noisy combinations is as bad as it gets. I found this was further lessened by using a SunRace cassette (Campag drivetrain on HG freehub).
From memory a Campag cassette on a Shimano drivetrain was noisier.
