Weak braking power from new XTR?
First off, I’m a professional mechanic for reference.
I installed a new XTR front brake on my XC bike and I still have a Magura MT7 on the rear.
I was riding it the other day and I just could not get great braking power out of it. I could lock up the rear Magura easily but the XTR would still move with a fist full of brake.
I know this won’t be as powerful as a Magura but I’m still shocked by this and wondering if it’s an install or contamination error or if my expectations are misaligned.
I am religious about avoiding contamination with my pads and rotors so before I replace those I wanted to check in to see if anyone has experience with these brakes.
the bleed is good. Lever hits resistance after just a short pull.
I did my regular in depth bed in process of 20 smooth braking to a near stop at a progressive level of speed. I also tried a hard but consistent drag on it on a downhill to really try to bed it in.
Which XTR brake is it? Enduro (M9220) or Race (M9200)?
4 pot enduro
Any noise when braking?
Sounds like contamination. Had this issue with a leaking bleed port on a Magura MT8 rear brake. I could not lockup the wheel. Have you tried sanding the pads and cleaning the rotors with IPA and then immediately taking it for a test? Sometimes a cracked piston or damaged seal can be hard to see and feel.
Did you use a new rotor? If not, strip the Magura bedding off the old rotor with red scotch brite and re-bed with new pads or pads scuffed up with 320 grit wet/dry paper.
I would do a quick sand of the pads and rotor and try doing the bed in again. Your bed in process is correct, but I find wetting the pads and rotor (squirting with a water bottle) before the bed in process creates a stronger transfer of pad material. Yes, the wet pads and rotors will howl during the process but they will be quiet again once they dry out.
Yep, new XTR rotor with the new brake.
Yeah, sounds like a contaminated pad/rotor. :rofl::zany_face:.
I’m going to try a new pad and rotor but it’s really annoying and expensive for all new brake parts so just wanted to see if this was a much weaker brake than I’m used to with my Maguras.
