Hi all, my Garmin Rally pedals only have a 15mm nut (no slot for a hex key), so I need to bring a pedal wrench whenever I’m travelling with my bike.
My current one is quite large and heavy, and I was wondering what a good travel-friendly alternative might be. Bonus points if it can also double as a Shimano lockring tool, so I can remove and install my disc brake rotors. Would love any recommendations if you have them. Thanks!
I have several travel frames with S&S couplers. There is a nice titanium coupler wrench that has a lock-ring tool on one end and a pedal wrench on the other. It also has multiple sizes of box wrench in the handle and a 1/4" hex driver that can be used with standard 1/4" drive bits (hex bits, torx,etc…) for making other adjustments on the bike. This tool can be used to tighten external-drive lock-ring center-locks for disc brake rotors (you might have to stick a glove or something between the curved portion of the tool and the lockring so it fits correctly - but I have done this and it works great). You can also make a small curved adapter wedge with your 3D printer. Da Vinci Tandems sells this Ti S&S tool, among others. Link below.
However, if you have the internal-drive type of center-lock-rings on your disc rotors this tool will not do the job. You could carry a separate internal lock ring tool (with a square drive) and then get an appropriate 1/4" to square-dive adapter and use the 1/4" drive socket on the titanium lockring tool to drive it. Another option would be something like the Wolf Tooth travel lock-ring tool with is an aluminum external lockring wrench with a magnetic bit holder on the other end. It comes with several bits, including an internal drive lock ring tool.
Oh, it’s a very cheap one from Wiggle’s own brand I got years ago, apparently it’s still being sold by a Swedish website here. It’s quite large and heavy, and I only need to use the 15mm side so the 9/16’’ side is useless to me.
My favorite lightweight, long, high-quality pedal wrench is a vintage one made by Eldi. Available on ebay, The only (non-hex key style) pedal wrench you’ll ever need.
Check out this Pedro’s Travel Pedal Wrench. I recently bought for travel and it seems of good quality so far. Looks like is can also pair with their pro socket tool for disc rotor lockrings and cassettes.
+1 for the Lezyne Saber have used it on a few bike trips for my Favero pedals, did their job perfectly well also it has a bottle opener, need I say more?
This is an odd gap in the market. I really wish Wolf Tooth would add this to its great Pack Wrench.
There are some thin 15 mm spanners which can be pretty light, just ensure they offer enough leverage. Along those lines, you could use a cone wrench if the pedals aren’t done too tightly.
I became a true weight weenie with my recent trip to Japan (where I used a OruCase B2 as my only suitcase, including bike). I originally had planned to take Garmin Rally pedals, but ended up using standard Dura-Ace pedals as it meant not having to pack a pedal wrench. From memory, that decision saved around 120-150 grams.
Be careful about using cone spanners on pedals - some of them have fairly soft jaws and might deform (i.e., Park), while others will be strong enough, but might be painful to use (i.e., Campag). Test at home first, not under time pressure.
15mm stubby open ended spanners are widely available, Kincrome make one that’s about $AUD10.
A crows foot spanner is even shorter but needs a 1/2" square drive. Combining that with a square drive cassette lockring tool would give you both the tools you want in a reasonably compact package
You surprise me Dave.
Presta Cycle filled that gap.
Although it would also be nice (& seemingly pretty easy and obvious) if the Wolftooth travel spanner included a 15mm slot.
I just travel with the 15mm spannee from my tool set. Just long enough for leverage and not too heavy. Have to remember to leave it a checked bag though as TSA rules on wrenches/tools in carryon are tricky. More a problem if you are only traveling with pedals for a rental bike vs if you have a bike bag checked…
