Scuffed Matt Frame - Help!
Have scuffed my matt frame and wonder if there’s anything simple I can do to improve it? Like some sort of polish. Don’t want to use fresh paint or start attacking with sand paper. I get that I can’t resolve fully, just want to improve a little bit - if possible.
Bike is a 2024 Tarmac Pro in midnight blue.
Thanks
Simon
Any kind of polish is likely to make it worse, as it will put more of a gloss sheen on the matte finish.
Best option is to try and find a similar nail polish color and just touch it up.
I would use a clear coat pen. The white marks will disappear. To keep the matte finish, dab the area with your finger a few minutes after applying. You will add texture to the surface finish that way.
There are also matte finish clear coat pens, but frankly I’ve had better results with what I described above.
I have similar scuffs on the inside of my Crux fork blades. In theory, since it’s asp matte paint, and also a Specialized, the clear coats of our bikes are the same. On my Crux the scuffs faded, or softened, significantly over time through many cleanings, to the point where I don’t even see it anymore. So, maybe just see what happens if you wet a microfiber cloth and go over for a few minutes, to see if it changes appearance at all. It might be that time just gracefully makes it less noticeable. Good luck!
Thanks. I’ve ordered a clear coat pen and will test it on a hidden frame part first.
As a child I was putting firewood into a slow combustion stove and coals rolled out onto the carpet. I considered spreading coals all over the carpet to provide a consistent pattern, and still after all these years wish I had done so rather than accept the wrath of my parents. Therefore I suggest randomly scuffing the rest of your frame. It will be unique, and future scuffs will not matter. Hope this is of assistance. My rates are reasonable.
This made me recall the time when, while working at a LBS, I had sold a customer a very nice high-end road bike. On his way out he parked the bike outside the shop, came back in and asked for a flat screwdriver. I watched in horror as he went outside and knocked in a couple chips, then added a scratch for good measure.
Handing the tool back he commented “there, thats done. Now I won’t have to worry about when it might happen.” Which made sense in an odd way.
The last time I bought a (used) road frame, I specifically looked for one that had some scratches and paint chips, for the very same reason!
Hey Simon, Drag about your scratches. I don’t offer a solution but just some perspective from a man close to 60. I spend years stressing over scratches, dings and stains on my cars and bikes when my kids we younger. I was always way to protective and focused on that which was not at all important. Today, I look fondly at those imperfections and realize they each tell a story. Don’t get me wrong, I take great care of my bikes mechanically but have learned to enjoy collecting the scars that a represent a life spent riding, falling and getting back up.
Hope you find the solution that work best for you.
Jon
“It only becomes really your bike after you went down together the first time”
