MTB short crank recommendations - 24mm axle
Looking to switch my MTB (Norco Optic) to 165 mm crank arms. Currently using a SRAM GX Eagle 12‑speed with a DUB crank, but I want a 24 mm axle crank to better suit the PF86 bottom bracket.
Ideally I’d keep compatibility with SRAM for now but planning to move to Shimano when the cassette is worn through. Current thoughts would be either a Shimano Deore or XT alloy crank
Have a look at Rotor’s MTB cranks. Great quality, light, modular and available in many lengths. Their more expensive road cranks start at 150 mm, I think.
RaceFace Aeffect are 24mm and available in 165mm.
