Lebycle BB Facing/Threading Tool
Just caught this in my feed, which looks intriguing. It’s for BB facing and threading, and available for about USD335. For a tool that gets rarely used (at least for the facing bit), it’s hard to justify the USD850 or so that Park Tool is asking, for its version.
Vars are also pretty hard to come by, and if this works as it says and proves durable enough, it might be worth getting down on.
@Dave_Rome, avoiding spoilers, but based on your current experience with Lebycle’s Disc tab facing tool, do you reckon something like the BB Facing and Threading tool might be worth the money?
I’m currently waiting on Lebycle’s response on things like the cutters’ and taps’ durability and replacements, but keen to hear what the folks here have to say.
This is what the AliExpress ad has to say about the tool:
  • Complete BB Shell Repair Solution The LEBYCLE BB Shell Tapping And Facing Tool Set provides a full solution for repairing bike bottom bracket shells with precision. Ideal for maintaining or restoring frame threads on various bicycle models.
  • Compatible with Multiple Standards Designed for BSA, ITA, and T47 bottom bracket standards, this tool set ensures compatibility with a wide range of bicycle frames. Supports accurate threading and facing for reliable performance.
  • Durable and Precision-Made Tools Crafted with high-quality materials, the Black BSA Tap, Black ITA Tap, and Black T47 Tap deliver long-lasting durability. Each tool is engineered for precise thread cutting and surface facing.
  • Includes Tap and Facer for Full Repair The set includes both Tap Tool and Tap Facer components, enabling users to both cut new threads and smooth the surface of the BB shell. Ensures a perfect fit for bottom bracket installation.
  • Compact and Lightweight Packaging Packaged in a compact case measuring 43 x 35 x 11 cm and weighing 5.200 kg, the tool set is easy to store and transport. Ideal for mechanics and DIY bike enthusiasts on the go.
Tough to say whether it’s worth the money, it’s still not a small amount for a tool that may see extremely infrequent use. That said, the quality I’ve seen from Lebycle as of late makes me think it’ll do the expected job. How well it’ll last or whether you can buy spares 3-5 years from now is anybody’s guess.
My counterpoint to this question is whether you need such a facing tool at all. Only some frames need it. How many times could you pay someone else to do it before you break even on this thing? If it’s for pro use, then just consider long-term access to replacement parts, including whether stupid alternative designs may surface in the market (unlikely for threaded BBs).
Further to what Dave said: the Lebycle tool looks good by itself but the tool interface does not seem to be compatible with other tools such as Park so replacement cutters may become difficult.
For a reasonable alternative, consider the “Super B” equivalent. It’s not quite the quality of Park but it is good enough for occasional use and it uses the same tool interface as Park so replacement cutters are easy. I used the Super B tool (BSA) on my first few frames then bought Park T47 cutters when I went to T47 as standard fitment. This worked a treat.
Also, be careful with the pricing on the Lebycle unit, the price you quote seems to be for one set of tapping cutters (BSA). Adding extra cutters (T47, facing) adds up fast.
Deeply appreciated as always, @Dave_Rome, @Lyrebird_Cycles_Mark_Kelly. Apologies for taking awhile to circle back.
I wasn’t aware (but embarrassed, because I should) of the differing tool interfaces. Comparing the Super B with the Park Tool, they do look similar, with the cutter on the Super B one is 50mm, a tad smaller than the Park Tool one, at 57mm. I assume that this is the reason that Mark went on with the Park T47 cutters eventually.
On Dave’s point about necessity, I’ve only been working on bikes full time for the past 4 years so very wet behind the ears. In that time, only had 2 clients come in with BB facing issues. In that time, I’ve probably had over 10 cases of cross threaded BB shells (of varying severity). This is actually the main driver for wanting a tool like the Lebcycle Super B. I keep coming back to this now and again, but could never justify the expense of say, a Park Tool, given how infrequently I need it. My only justification is that the tool will mostly be used for cleaning up a cross threaded shell, with the ability to face shells a nice bonus. As such, not having to shell (ha) out excessive funds would be quite nice.
Since I last posted, Lebycle has responded to say that their cutters, if used with cutting fluid (no word on the durability of the taps);
  • Aluminum: approximately 1000x
  • Common steel/Cro-mo: approximately 500x
  • Titanium: approximately 50x
And the diamond grinding head rated 500x for CF. Replacement taps/cutters are only available directly from Lebycle.
I’ll very likely go down the Super B route, given that they’ve got some local repping them, which at least reduces shipping costs, and I’d reckon replacement taps/cutters to be fairly affordable, given their smaller form factors.
So, thanks again! :handshake:
I’m willing to pay for high-end tools that I can use and often that I don’t use very often.
However, this is something I won’t be acquiring. I will seek appropriate care for this.
