Integrated bar/stem or separate components
Hoping for some opinions on a first-world problem!
I’ll soon be receiving a frameset to build-up and it uses the Enve In-route AR fork. I’m decided on using the Enve AR handlebars because the shape is very similar to my favorite bars, Zipp XPLR. I’m undecided though on whether to go with the integrated bar/stem or the separate components. I’ve never gone with an integrated setup before for a couple of reasons, which may or may not be valid.
Firstly, I feel that handlebars are a kind of vulnerable component in the event of a crash or rough handling when traveling with the bike. So I’d rather just replace a damaged bar in that event.
Secondly, not having had integrated bars before, I have a feeling that they could be more of a PITA when packing the bike in it’s travel case, which I will need to do at least once.
Any experience and advice from the EC hive mind would be much appreciated. Cheers.
I prefer separate bar and stem for fit flexibility and cost of replacement concerns.
I don’t think it’s actually a concern for packing a bike because I always just pop the bar and stem off together. It’s fewer bolts to undo and you don’t need to worry about getting the bar tilt just right again.
If you’re worried about it I would just get the separate bar/stem. Either solution is probably negligible in labor time to replace but the cost will be lower to just replace a bar.
Ditch practicality, polish the look!
If money doesn’t matter, give it a try. If money does matter, I’d go two piece.
Limiting your fit options that much doesn’t seem like an awesome idea (in my mind). But some folks are able to ride almost anything and thrive so if that’s you, and you love the aesthetic, have at it!
Yes, I’m leaning towards separate for those reasons.
I used to have a Scott Addict RC with fully concealed hose routing and I found that I couldn’t do that (with separate components) without also unbolting the front caliper because the hose run to the front is so direct. But I think that would be the case either way… I’m screwed!!
If you know your fit, I usually tend towards the integrated solution, but travel is a valid concern. However, a two piece solution does not help much if the brake hoses are running through the stem, not beneath it. After all it is just about our personal preferences, how you weigh looks and potential marginal gains vs. practicality.
