As you said, there are many options.
The problem is, you don’t really know what your preferences will be.
I’m a bike fitter, so I’d say the number one thing is a good fit. Do you have a good fit on your road bike? If so, I’d look for a frame that will allow a similar fit.
You might consider a slightly more upright fit, if you plan to do some longer rides in gravel than you do on road (time wise).
If your rides include rough washboard, or more difficult and rough terrain than good gravel roads, you will likely want to ride in the drops a lot more than you do on your road bike.
For those customers, I often fit them to the drops with the same torso and arm position as they would have on their road bike on the hoods. Then they can use the hoods with bent elbows in the “aero hoods” posture, for speed on smooth roads.
As far as geometry goes for roadies getting a gravel bike there are 2 schools of thought:
Some people prefer a more road like geo (short wheelbase, steep head angle etc), because it’s what they know and love, and they enjoy that feeling.
Others would say, build the bike to your weaknesses: so, lacking as much experience in rough, steep and loose terrain, optimize the bike to make that easier: Slacker head angle, longer wheelbase (long chainstays, long reach, short stem).
The one thing I’d say (as others have too) go for versatility, since you don’t know exactly what you will get into and prefer.
So, that means big tire clearance and an easily adjustable fit and cockpit. Ideally a suspension corrected fork, so you can swap to a suspension fork later if you discover you’d want that.
Wanting a “fast” bike is a difficult one. A bike that feels fast is fun to ride on shorter rides and good roads. But, typically that means stiffer ride quality, firmer tires, lightweight wheels and skinny tires, because they are lighter). This makes a lively, quick accelerating bike that is so fun to ride on good roads.
The drawback is that those attributes often make a bike slower on less smooth terrain and fatiguing to ride for longer time periods.
