This inquiry relates to a SIDLuxe Select+ 3-position A2 shock (RS-SIDL-SLP3-A2). The cable pulls for this shock lockout are 7 mm + 7 mm. The routing style in my setup is backside (to be distinguished from in, out, and 90 degree styles).
The instructions for setup clearly indicate that you should pull the cable fully taut, make sure all ferrules are fully seated, and then secure the cable to the dial while it is in the fully relaxed open position. I am glad that I installed inline barrel adjusters because this just seems fundamentally wrong–specifically, it seems that the dial needs to be preloaded quite a bit to actually hit all 3 positions with 7 mm + 7 mm pulls. For me, it was quite clear I could hit open vs. pedal but there really wasn’t an immediately apparent difference between pedal and lock.
It wasn’t until I added significant tension via the inline barrel adjuster (seemingly like 4+ mm of preload) that I could get 3 very distinct settings, especially where pedal vs. lock was noticeable. It is my understanding that there are 3 discrete settings—not a continuously variable adjustment. I.e., you have either hit pedal or full lock completely or haven’t hit it all.
There are a few threads on MTB Reviews that suggest setting up in the opposite manner by securing the cable initially when it is in a looser full lock setting and the trigger/twist-lock is in the full lock setting. In my experience, this seems like it would lead to user success more readily than SRAM’s current instructions.
For what its worth, my SID Ultimate 3P fork (FS-SID-ULT3-D1) produced 3 discrete settings much more readily than the shock. With that said, without a barrel adjuster I doubt I would have gotten it correct on the first try by simply following SRAM’s instructions. Some amount of preload was probably necessary.
Anyone else setup their 3 position lockouts in this manner or feel that they need to significantly preload the dial?
Full disclosure, I am running a 2026 Fox Twinstick (Part number 925-06-007) to control my Rockshox suspension components. On the Fox site, it doesn’t specifically indicate that the Twinstick uses 7 mm + 7 mm when using the 3 position cam. However, a number of vendors selling the Twinstick specify 7 mm + 7 mm. I took some measurements of cable pull, at least as accurately as one can with a marker. The first pull is definitely 7 mm, although the second pull could have potentially been like 5.8 mm to 7 mm.
I am going to reach out to Fox for full confirmation that they do use 7 mm + 7 mm on for their 3 position cam on the Twinstick.
