Disc Brake Facing Tool
I’ve had my eyes on a facing tool for a long time. However they’re expensive and sounds like there’s no point in buying a cheap one.
However this popped up on my YouTube feed: https://youtu.be/e-Y680iQwMs?si=YHNK1hzXBXAWt2jV
@Dave_Rome have you managed to test one?
Thanks.
That video also popped up on my feed. Now, I noticed that the corresponding Park Tool tool is heavily discounted right now. The price difference is not enormous anymore. So, I ordered the Park Tool.
Seems I was a week too slow on this one. New Tools Day later this week will offer a first look at this plus some preliminary thoughts
Then expect a bigger comparison article covering this product segment and the competing options.
Thanks Dave. I look forward to the articles. I’ll hold off splashing the cash for now!
Must be a tiny number of individuals purchasing disc brake mount facing tools for their home shop. Having said that, I purchased the Park version for my home shop and have been very happy with it. Not looking to save money on this kind of thing; I just needed it to do its job well…budget was secondary.
It (still) is a very expensive tool. And you only need it a couple of times. But if need it…
I think that’s kind of the point. For the tool, any tool, to actually be good, it’s going to have to cost, and the more refined/accurate the tool needs to be and/or specialist (meaning low volume and high R&D, if not just copying), then the higher that cost will be.
That Lebycle disc facing tool, if distributed in the same way as Park Tools, would be more expensive than Park Tools. Not just a bit more expensive … a lot more expensive. I’d say that’s pretty interesting in itself.
Same guy reviews this tool and looks more interesting to me as a home mechanic. He uses it on my exact metal gravel bike too.
I have that one. It kinda works. If you only need to use it once or twice and you don’t need precision work, it’ll do.
I personally would avoid that. I’ll cover why in the dedicated feature, but the short answer is that you can’t put the material back if the tool mucks it up.
For now, an early first look of the Lebycle tool has been published: Threaded #62: New tools from PrestaCycle, Remco and more
Isn’t brake mount facing the definition of precision work? At that point, may as well just not face them. (saying this half tongue-in-cheek)
People’s definitions, or rather needs, may vary. Some just want no rubbing, others want absolutely no squeal and even pad wear.
In the ideal world, no-one would ever need one of these tools. If the frame is made properly, the brake mounts are square. If they’re not, that’s the maker’s problem, not the buyer’s.
Dream, I know, and this particular problem never cropped up on any of my frames, partially because I outsourced the solution to Paragon with 100% success, that being part of why they were the go to for so many of us.
On the other hand I did send a couple of frames out to owners with other errors I hadn’t spotted. These were my fault so I owned them and made them right. Is this so hard?
Just posting this here, in case it can inform the discussion: https://www.facebook.com/BarnettBicycleInstitute/posts/disc-mount-milling-mythbustedbbi-loves-tools-at-bbi-weve-got-a-well-developed-of/1073120916062427/
A brand/manufacturer can always make a mistake or forget something. Unfortunately, acknowledging something and providing decent customer service is something not all vendors are willing to do. Now, I didn’t even contact mine. My frame came from another country and covid19 was in full swing. At the time, I solved the issue by shaving off parts of the flat mount adapter. Now I want to properly face the mounts. I keep the tool for other frames and for friends.
Disc brake mount facing does not have to be complicated.
It can be done with very simple tools, as described by Alex Meade here:
This method can be used on all flat mount and post mount frames and forks where the tops of the mounts are not obscured or obstructed by other frame features.
For those that don’t know Alex, he’s a treasure.
I designed and built my own frame jigs because the standard ones didn’t suit my non-standard build process.
Alex made all the custom bits that I couldn’t and did a great job.
Unfortunately, one of the tools you need is Instagram. And that’s too pricey for me, personally.
