Compatible cranksets - Deore XT 10 speed
Brains trust:
I have a lovely old 26” MTB that is used to take my toddler off sweet jumps and imbue her with a love of bikes. However, it has come with a 175mm crankset and it is brutalising my knees.
I am looking for a recommendation for a replacement where ideally I can drop it straight in. Maybe some shifting tweaks but I’d like to avoid buying other stuff. Therefore: 24mm spindle, 165-170mm arms, compatible with 10 speed Shimano from 12(?) years ago.
Before you ask: I have googled and before America took the power away I did ask Fable 5. Please help!!
Ideal: crankset with same bolt circle and chain line, shorter arms, move current chainrings over to New crank
2nd ideal - new 2x crankset with same chain line (including new chainrings), shorter crank arms
I’m guessing that bike/groupset is still has 135mm-spaced rear hub, which would be 46mm 2x chainline, if I’m understanding correctly.
Shimano FC-4100-2? I’m seeing it with 170s.
Universal Cycles – Shimano FC-M4100-2 Deore Double Crankset - 10 Speed [EFCM41002CX66, EFCM41002EX66]
Would one of the new CUES cranksets work?
Universal Cycles – Shimano FC-U4010-2 CUES Double Crankset - 9/10/11 Speed [EFCU40102CX06X, EFCU40102EX06X, EFCU40102CX60X, EFCU40102EX60X]
I was wrong about the chain line. I was assuming simply that they were optimizing chain line for where the cassette was, without thinking about the added incentive of fitting wider tires.
The chainlineon yours is 48.8
Both of the models linked by @Peter_Burghardt should work.
Where are you? I have what I think is an identical XT crankset in 170mm I’ve been meaning to get onto eBay for ages.
*I’ve now read all of your post … looks like you’re in the US. I’m in UK so probably not an option.
I am in Australia sadly!
OK! Now we are cooking! So I can just buy a 2x Cues and get back to living the dream?
That is an amazingly simple solution. Thank you
CUES CRANKSET HOLLOWTECH II 2x10/9s
The specs look correct, but I have not installed one of these.
Also on the Shimano AU page:
MTB CRANKSET 2X10s
DEORE CRANKSET FOR 135/142 MM O.L.D. FRAMES 2X10s
If you don’t need the low gearing:
GRX CRANKSET 2X10s
Hiya, I’m in the UK and I could be interested in that.
