Chafing on MAAP Team Bib Evo Thermal Cargo Tights
Anyone else having this chafing issue on the outside of the MAAP Team Bib Evo Thermal Cargo Tights? I have worn this pair for no more than 4 times and I just noticed it when I put it on last weekend. This pair of tights is my only MAAP thermal tights and I do not have similar issue on other MAAP bib shorts.
You don’t happen to have a 3d printed saddle do you? Asking given it seems to be a known issue that 3d printed saddles can chew through shorts/tights, but given you say you’ve had no issue with the shorts, I am maybe joining dots incorrectly.
I have the Specialized S-Works Power with Mirror on the road bike and the Power Pro with Mirror on the gravel bike, on which I did most of the four rides with the tights. Both saddles are 3D-printed. Other than this MAAP tights, no other bibshorts (Castelli, Rapha, Giordana, MAAP, Ornot) suffer from this wear.
This is very usual wear. If those were my tights I’d reach out to MAAP. No telling why this happened. Maybe it was a bad batch of material.
This is a stretch, but…
I’d be curious if a particular cleaning chemical was recently used on the saddle, either a new product or something that wasn’t rinsed off as thoroughly as normal.
No cleaning chemical used on the saddle. In any case, I showed the photos to MAAP customer support and was told to submit a warranty claim.
