50c tire on a Roval Terra C (25mm internal)?
My gravel/commuter bike (Spec Turbo Creo 2) came with the Roval Terra C wheelset; they are 25 internal/30 external and Specialized recommends max 47c tires.
I’m curious if there would be any real issue running 50c tires on those rims.
The frameset can clear 50mm tires, and I’m running tubes and the rims are hooked. But with a 25c internal width would it be too much of a “light bulb” shape to the tires that would pose a danger to the sidewalls?
(This is my first gravel bike / first time dealing with tires this large. On my road bikes I run 32c tires on 21mm internal rims; obviously the ratio of tire width to internal width would be much higher with the 50c tire)
100% not a problem. When I started mountain biking in the nineties, everyone ran 2.1 tyres on 18mm rims. No-one thought or knew any different.
I currently run 2.2 on 25mm internal carbon rims on my gravel bike. Would I like wider? Maybe. I have 30mm internal on my MTBs with 2.2 and 2.4.
However, 50 on 25mm rims is totally within ETRTO standards. Is it optimal? depends what you consider optimal, or whether you care about what would be pretty marginal performance differences
Good point about the 90s. I had a mountain bike with wide tires and I’m sure I never heard anyone talk about ETRTO.
Is there any like minimum tire pressure for this kind of setup? I’m currently running 40psi on 42c tires, I assume 50 would be around 30psi.
I’ve never heard of minimum pressures being stipulated except on the side of tyres, and I’m regularly well below those. I would say you know the minimum cause you’ll feel the tyre squirming or bouncing strangely. Next sign of being too low would be a pinch flat, but that could also be careless line choice.
I’d be more concerned about the maximum, as failure at that end will be more spectacular, though as you are running tubes, you have much more margin, to the point that the main issue with going h too high would be that you defeat the point of going bigger.
Just go check one of the various online pressure calculator tools and start with what comes out from that.
On gravel?? Man, that’s rattle your teeth out stuff - couldn’t do that around here. I run 24psi on 48c tyres despite running a ShockStop stem!
no no - on the road. Mostly a commuter bike.
However I’m totally new to gravel bikes and I’d experiment with lower pressures. I just set it at 40 based on the Silca calculator
Zero problem. My XC MTB rims have an identical internal width. I ran anything up to 2.3" tires, and the only reason I didn’t cram in 2.4" was a lack of frame clearance.
The Silca calculator aims for the fastest pressure for a given system. That may be true, but personally I treat it at a max from which I experiment, I tend to find the sweet spot for me is 10-15% less than Silca recommend, it may not be the fastest but it’s much more comfortable, and more confidence inspiring.
50 on 25 might not be the trendiest thing but absolutely no problem, especially with a hooked rim. BITD I did a several thousand km offroad tour on 2.2" tyres on ~i23 rims and had zero issues despite very low pressures at times, this with tubes.
People get too invested in what’s new/fashionable, rather than what will work. As for pressure, it’s worth experimenting. FWIW, I did lotsa MTB rides on ~50mm tyres at circa 30 PSI in the nineties and no teeth fell out.
Thanks for that. This wasn’t a fashion question - rather I was asking about safety, as I don’t have experience with tires this large and 50c is beyond Specialized‘s specs (but not beyond ETRTO)
Understood! Lots of hand wringing elsewhere about aeroness and up-to-dateness with less than humungously wide rims though, which seems a bit comical to me based on past experience.
